Old 11-11-2014, 04:25 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
Steering wheel squeaking?
Old 04-14-2011, 05:51 PM
Charlie01's Avatar
Charlie01
Charlie01 is offline
My steering wheel squeaks when turning and it drives me crazy. I'm tired of turning up the radio up so I don't hear it lol. I have been told that there is a bearing in there that it known for causing that. Is it possible to grease it up or should I just replace it? Is it difficult to do or do I risk messing up my air bag wiring or anything else? If anyone has experiance with this and could give me some advice I would appreciate it.
Old 04-14-2011, 06:38 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
There are a couple bearings in the steering column. If they are squeaking, they are probably already done.. Does your steering wheel move up and down a little bit?
The parts are available from Ford if you want to try just changing the bearings, but when I tried to do it, mine had a messed up shaft also, so I had to change the whole column.. So, I didn't get to finish trying it to be able to tell you how it's done. It IS a PITA though, I promise you that.
Old 04-14-2011, 06:45 PM
terrapin88's Avatar
terrapin88
terrapin88 is offline
I have a squeak when it's cold, but it goes away once things warm up a little. It was driving me nuts too and it sounded like a spring that was about to pop. I did a little research on here and this is one of the posts I found that gave me an idea of what might be going on. You can read this and search from there.
https://www.ford-trucks.com/forums/9...ing-wheel.html
Good luck.
Chris
Old 04-14-2011, 07:13 PM
jl109's Avatar
jl109
jl109 is offline
Mine's squeeked since it was brandnew..... I've way ignored it. Drives my wife insane
Old 04-14-2011, 09:10 PM
Krisx125's Avatar
Krisx125
Krisx125 is offline
You sure it aint ya balljoints?
Old 04-15-2011, 11:27 AM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
Mine was the bearings in the column. Thanks for bringing that back up. I updated it with this info.
reggiedunlop
1983 - 2012 Ranger & B-Series
05-28-2017 11:48 PM
Mattman81
01-17-2017 12:38 AM
chief1600
1999 to 2016 Super Duty
09-08-2016 02:21 PM
happylulu
1997-2006 Expedition & Navigator
11-05-2010 05:50 PM
spdmpo
13
05-28-2010 10:17 PM
Quick Reply: Steering wheel squeaking?
