How to get rusted rim off hub? Need advise - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 04-14-2011, 06:42 PM
EconolineFan EconolineFan is offline
EconolineFan is starting off with a positive reputation.
I am trying to remove my right rim on my 95 E150 from the hub but it seems to be rusted in place. I tried:
1) Penetrating spray (still waiting for it to set fully)
2) Beating it with a rubber mallet
3) Wiggling it side to side (won't budge)
4) Prying it with a flatnose screw driver and only ended up breaking two good screwdrivers.
Any ideas on how to remove this rim?
Old 04-14-2011, 07:27 PM
I am at a loss as what to do now. I got new brake pads on one side but this side wheel wont come off. So now what. Bad situation.
Old 04-14-2011, 08:28 PM
daveshomeservice daveshomeservice is offline
daveshomeservice is starting off with a positive reputation.
Hit it with a bigger hammer!! with wheel off ground, lug nuts loose, place a block of wood on rim,or a 2 x 4 across rim held in place with clamp, and take a good swing at block of wood. I use a wood splitting axe with a 3 foot handle, good luck
Dave
Old 04-14-2011, 09:05 PM
Thanks Dave, should I hit from the outside or underneath the van on the inside?
Old 04-14-2011, 09:23 PM
Fordranchero's Avatar
Fordranchero Fordranchero is offline
Fordranchero is starting off with a positive reputation.
The bigger hammer may work but I've had better luck with less damage by loosening wheel lugs and making a few tight turns in the back yard ( I've got a big back yard so if you don't, improvise).
I've had rims that I almost beat to pieces, heated up, tried everything and did loose wheel thing and they popped.
Old 04-14-2011, 09:34 PM
YoGeorge YoGeorge is online now
YoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to behold
I agree with Ranchero. Loosen the lugs just a tiny bit and drive the van a bit (the circles thing sounds like it would work well); that should break the rim loose, especially if the penetrating oil has been slowly working its way in.
Good luck,
George
Good idea! I live on a cul d sac so driving in circles is no problem lol. How loose should the lugnuts be? Perhaps just hand tight? I will try this first thing in the morning if it does not work I'll go buy a big hammer and wood.
Nothing can happen by driving with one wheel that has fresh brake pads and other old ones right? As long as it's slow driving?
Old 04-15-2011, 08:11 AM
Maybe two three turns, just try it, it's not science.
No , it's not going to hurt it driving with new brakes on one side and not the other.
Old 04-15-2011, 11:04 AM
The loose lugnuts/driving trick worked like magic! The sucker popped like a needle to a balloon. New brake pads on and I am one happy camper. Thanks for your help everyone.
Old 04-15-2011, 11:14 AM
Good news, EcoFan! It's hard for a rusted-on wheel to argue with the weight of the van and saves a lot of energy beating on the wheel.
Take care,
George
Old 04-15-2011, 01:54 PM
Save bashed knuckles and bent rims!
Old 04-16-2011, 12:22 AM
Rico47635's Avatar
Rico47635 Rico47635 is offline
Rico47635 is starting off with a positive reputation.
And possibly a busted windshield or several dents from flying tools. I hate it when that happens!
Old 04-16-2011, 11:02 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
a few years ago in an 83 LTD, some person i won't mention installed a pair of rims from a FWD ford (same 4x4.25" bolt pattern, slightly smaller center hole), and i got to it in the spring when it was time to take off the studded tires. after trying the loose nuts trick, including abusive braking in both forward and reverse, and spending much effort with a BFH, it still hadn't budged. finally, i tore apart the rear axle, put the wheel/axle shaft assembly in the press, and just over 5 tons of force was required before the shafts popped out of the rims.
its good to hear you got it off without too much fight!!
Old 04-17-2011, 05:58 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
I'm okay with these sorts of accidents-----only coz I'm in the auto glas biz!!
Might also be a good idea to lightly coat the back side of the wheels with anti-seize----some think that's over kill but it can't hurt.
Adding that removing all lugs except two on opposite sides then moving the van forward or backward just a touch before slamming on the brakes----assuming you don't have a convenient cul-de-sac or big back yard.
As far as how loose to leave the lugs I'd let just leave the very bottom of the lugs "touch" the wheel hole, not so much the wheel could **** on the studs, possibly bending them.
Hopefully this isn't a common problem but it can be a PITA when it happens.
Custom rims with manual lock 4x4 Jesses1999f250 1999 - 2003 7.3L Power Stroke Diesel 3 03-05-2015 11:21 AM
How to remove OEM steel rim chrome covers. xmontex4 1999 to 2016 Super Duty 6 10-31-2013 02:04 PM
split rim\ tubeless tire 99hosss 1961 - 1966 F-100 & Larger F-Series Trucks 12 07-12-2011 08:58 PM
steel rims green53 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 02-19-2011 08:49 PM
Rim pics? Redneckryder 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-01-2009 03:01 PM
Tags
axle, f150, f250, ford, hub, hubs, remove, rim, rims, rusted, rusty, seized, vans, vehicle, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
