Scangauge normal readings 6.0 Xgauge
Hey fellas got a stock 05 F250 6.0 that is giving me problems for about 4 months now I have been reading on here the whole time about what to do and done it and the thing still wont start when hot! EOT 177-ECT 174 ICP 586 when running and 286 while cranking IPR 28. something when running and 77.6 while cranking when I have a no hot start. I have Replaced Standpipes, dummy plugs, ICP Sensor, IPR, STC, Injector orings, ICP pigtail, FICM 47.5. Took it out night before last after replacing all injector orings and it restarted after about 15 mins of hard driving, next day hauled a desk 15 miles going to back it in the drive and it died in the road(thankfully it made it there) Waited 5 hours started back up. I love the truck but just about ready to get rid of it. Going to run another air test when she will start again, let it run for 1 hour this moring to get scangauge #'s and now wont restart. Do you guys think I should throw a new HPOP in it?
Yeah figured that much but the truck is too far from the garage to do that right now, is there a reason every oring would be going bad, oil cooler clogged super heating oil because every injector oring was bad(burnt or broken) dummy plug orings worn standpipes not to bad has something happened to cause all of this?
on
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
can someone please help me decipher this? I believe my EBP is measuring in PSI and from what I remember people were saying to should be somewhere around 15 psi KOER? Is that correct? It should also be similar to the baro pressure KOEO?
Thanks
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
Thanks
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO= 15 Low Idle= 16 High Idle= 16 OR= 8 -88 PSI
Thanks
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
Thanks
Here is a video of EBP while running down the road. At 1:26 starts the EBP readings, with a WOT.
These are my values please help me out with what you can.
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
12.5 13.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
12 13
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
47.5 48
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
0 85 52 wot 49
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
5 584 1903 wot 2205
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
.23 .81-.82 1.67 wot 2.47
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
14.4 22.1 35.5 wot 55.91
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
0 29 30 wot 42
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
This one is blank checked the code twice still doesn't work
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
.8 1 1
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
0 0 0
Barometric Pressure
TXD: 07E0221127
RXF: 045285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
This one also doesn't work
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
15 16.8-17.1 26.1 wot 48
MAP
I didn't enter this one it was preloaded by scangauge
OR 24.4
WOT this was weird it increased to 31.0 then dropped to 2.1 then back up to 33.9
Also KOEO
EBP 15
MAP 14.4
I used the BAR (Barometric) that scangauge has and it just sits at 26.9 so I don't think it works.
Also I've seen my EGR spike to 64
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
12.5 13.5
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
12 13
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
47.5 48
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
0 85 52 wot 49
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
5 584 1903 wot 2205
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
0 29 30 wot 42
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
.8 1 1
TXD: 07E02209CD
RXF: 0462050906CD
MTH: 000100010000
NAM: SYC
0 0 0
Barometric Pressure
TXD: 07E0221127
RXF: 045285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
MAP
OR 24.4
Also KOEO
EBP 15
MAP 14.4
Try this Xgauge for BAROMETRIC
07E0221442
046285140642
3010
001D00500000
BAR
Also, on the crankshaft & Camshaft, have you tried both?
The EGR ones were hit and miss on the 04 and early 03 trucks. I have a late build 04 and I didn't have much luck on those.
Nothing jumps out at me with the readings you have posted. Except of course the Cam Sync.
07E0221442
046285140642
3010
001D00500000
BAR
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
12.5 13.5
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
12 13
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
47.5 48
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
0 85 52 wot 49
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
5 584 1903 wot 2205
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
0 29 30 wot 42
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
.8 1 1
TXD: 07E02209CD
RXF: 0462050906CD
MTH: 000100010000
NAM: SYC
0 0 0
Barometric Pressure
TXD: 07E0221127
RXF: 045285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
MAP
OR 24.4
Also KOEO
EBP 15
MAP 14.4
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
12.5 13.5
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
12 13
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
47.5 48
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
0 85 52 wot 49
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
5 584 1903 wot 2205
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
0 29 30 wot 42
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
.8 1 1
TXD: 07E02209CD
RXF: 0462050906CD
MTH: 000100010000
NAM: SYC
0 0 0
Barometric Pressure
TXD: 07E0221127
RXF: 045285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
MAP
OR 24.4
Also KOEO
EBP 15
MAP 14.4
When he goes to Alaska, he is going to see lower ECTs than that. As soon as ambient temps are below 60 f it's not uncommon to see your ECT dip down below 185 for periods of time when your running downhill or simply idling at colder temps. I had this often with old thermostat and now with new one. It's perfectly normal. Also, when you see EOT spread over 15 degrees as well it's common at these lower temps because there isn't the water diverted to thx he EGR and oil cooler when the ECT is below 185. It's why I run a winter front and even extra cardboard in really cold weather. Ie -20 f or colder. Just can keep any heat in her, coolers are all to efficient.
#29
#30
Here is another list (check the PDF file in the first post):
https://www.ford-trucks.com/forums/1...-attached.html
99ExpyProblems
11-14-2014 08:37 PM
