Rear End Question
You can change the rear drum to discs, no problem. I would recommend it before using a Versailles rear today. 20 years ago, that was the hot setup. Everyone wanted one and they sold for big bucks. Today, many of the parts are obsolete and if you have worn or broken parts, or are missing a little bracket or spring or spacer or etc., you're screwed. If you've just got to have rear discs, a late model Explorer rear end is the way to go these days. Don't even consider a big Lincoln rear. They're way too big and have an oddball wheel lug pattern.
Originally Posted by wakeboarder
'77-80 Lincoln Versailles 58" (has rear disc brakes).
Rear Disc Brakes w/a 9 inch: 1975/76 Continental Mark IV & Thunderbird / 1975/78 LTD/Mercury Marquis / 1975/79 Lincoln Town Car / 1975/80 Granada/Monarch/Versailles / 1977/79 Continental Mark V.
This will help:
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps .: Articles
If you want a rear end I have a 9" from a 67 f100 (3.25 gear ratio with open diff) I bought for my '56. It's a spot on match in width and the spring perches are in the right location. No cutting and welding, it will bolt right in. I even have the u-bolts for the drive shaft, u-bolts for the spring perches, wheels, and the emergency brake cables all the way up. It is a complete swap and requires hand tools. If you want pics I can get them. And I am in NC, at Ft Bragg. So not to far from your project.
I went off this article for the direct swap data: F100Central.com - Articles - Rear Suspension - 53-56 F100 Rear Suspension
Only disadvantage if you are hot rodding. Non posi (Open diff) lets one wheel get the most traction. This was designed to let the rear wheels rotate at different speeds when cornering to prevent tires from scrubbing around turns. Often called "one wheel wonders".
They can easily be converted by replacing the "innards" with the "limited slip" or "posi-trac" unit.
#28
the way they work is to clamp both axle halves together with spring and clutch pressure, until the pressure to move separately overcomes the friction force of the clutches.. (thus they are 'limited' in the amount/time they 'slip')..
now comes the problem. around a corner, the outside wheel wants to travel further than the inside wheel, but they are hooked together.. somethings gotta give. on solid axle vehicles, the inside tire skips/grinds/wears cause the outside applies more torque.. on wet roads it just slips eventually,
with the LS, like the solid axle the inside tire just slips.. now stomp on the gas (a little to a lot), and cause the outside tire to slip,
and voila, both do!!.. and the rear end is now sliding sideways..
(I now understand why I smashed by Dads Barracuda into the center divider turning left at the light (just started to rain), when I stomped it to impress my girlfriend... ah to be 17 again!)..
cops cars do NOT have LS to prevent this very thing, and most production cars don't either. too dangerous as a stock feature where most drivers don't understand the side effects. Open Diff spins the tire with the least friction, but the other is dead.. so, at least you have road surface friction, altho no acceleration.
I rebuilt the 8.8 LS in my green truck to add one more friction surface to increase the clamp, and an increased pressure spring.. with 435hp I need both tires to smoke when I stomp it!
As Dave mentioned, replace the carrier guts with an LS version, poof, you have LS. (most diffs cannot be converted)
Sam
#29
rear end
Awesome, thanks for the great explanation! I think I will get that 9" off John, Nothing better than something that will fit perfectly, and only a two hour drive! I will probably use it the way it is for now and then get the LS later on, as for me i need both tires to spin too! Thanks guys!
RÖENTGEEP
07-25-2011 11:36 AM
1949, 76, 7780, continental, differential, end, international, lincoln, picture, rear, trucks, versailles, wheel, wide, wire
