99 ball joint replacement questions
99 2wd F-150. Driver side upper ball joint has some slope in it. In my research I am finding conflicting info. I have read most of the pages in this huge ball joint thread- https://www.ford-trucks.com/forums/3...f-150-4x4.html and they touch on it here and there but I'm still a little confused. Ford says the upper ball joint is part of the a-arm and cannot be pressed out. Some of the parts stores and online shops I have checked sell single upper ball joints with out the a-arm. What the heck???
I understand the lower one can be pressed in/out.
I assume Auto Zone or the like will have a cam bolt kit for this proceedure in stock?
Are Dormen brand joints any good or stick with moog?
Thanks.
Thanks.
I personally stick with moog. And Autozone does sell the camber/caster set for doing an alignment. When I got my Bj at Advance I somehow wound up with a lifetime replacement on my BJ's. Something you might want to look into. As far as the upper BJ without the A-arm, never seen it so I can't say anything about it
jarhead6919
1997-2006 Expedition & Navigator
03-21-2012 08:30 PM
bill6302
06-02-2005 07:22 PM
