Turn signal lever 2011's - Ford Truck Enthusiasts Forums
Old 04-14-2011, 08:11 AM
XXX4play XXX4play is offline
XXX4play is starting off with a positive reputation.
Anyone else not liking how the new turn signal lever operates? Its very easy to turn on in the wrong direction when you turn it off!!
Sure doesn't work anything like the 2009 and beyond
Old 04-14-2011, 08:24 AM
Mikey D1016's Avatar
Mikey D1016 Mikey D1016 is offline
Mikey D1016 is starting off with a positive reputation.
I seem to like it. I have only had my truck for 3 days and I am used to it. Its a matter of preference I guess.
Old 04-14-2011, 08:50 AM
ratucker3's Avatar
ratucker3 ratucker3 is offline
ratucker3 is starting off with a positive reputation.
Like Mine
I actually like the turn signal on 2011 XLT crew....makes lane changing nice when you just touch the lever......sort of like most german vehicles.
Old 04-14-2011, 08:52 AM
David Gordon David Gordon is offline
David Gordon is starting off with a positive reputation.
Lots of new cars have gone to this.
Old 04-14-2011, 09:33 AM
OmahaEcoBoost OmahaEcoBoost is offline
OmahaEcoBoost is starting off with a positive reputation.
After 3 weeks I'm not a fan. Too often it won't shut off when changing lanes and then I push it the opposite direction only to turn it on going that way. Actually turns are fine but lane changes get annoying after awhile. Even bumping it will turn it on randomly.
Old 04-14-2011, 09:46 AM
nicemustang nicemustang is offline
nicemustang is starting off with a positive reputation.
I am definitely a fan. It's been this way in the VWs for years. Not sure how one turns it on the wrong way to turn it off. To turn it off, you don't go back, you go same direction...
Old 04-14-2011, 09:48 AM
I'll have to give that a try. That would certainly change my opinion if that works.
Old 04-14-2011, 09:52 AM
flisom flisom is offline
flisom is starting off with a positive reputation.
turn signal
I didn't like it initially, but now I do. Once I understood the lever has two setting it made all the difference. If you push the lever gently it will go into lane change mode and your signal light will blink 3 times then shut off automatically. If you push the lever to the full extend the signal light will stay on until you have turned or manually turn it off. The signal can be turned off by simply tapping the lever up or down. It doesn't matter which direction.
Old 04-14-2011, 06:00 PM
jimmyb08SD's Avatar
jimmyb08SD jimmyb08SD is offline
jimmyb08SD has a very good reputation on FTE.jimmyb08SD has a very good reputation on FTE.jimmyb08SD has a very good reputation on FTE.jimmyb08SD has a very good reputation on FTE.
Ok now I may like it also, was not a fan until you guy's educated me! Thanks.
Old 04-14-2011, 06:10 PM
tseekins's Avatar
tseekins tseekins is online now
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
My wife doesn't care for the signal lever but I like it a lot.
Old 04-14-2011, 07:46 PM
Got them to turn off ok finally, thanks for the info
Old 04-14-2011, 07:55 PM
Must be different
Yes it works on mine. I have the FX4 w/ luxury package. Just push the lever part way up or down and the it will blink 3 times and then turn off. I have to push it up or down all the way to work normally.
Old 04-14-2011, 08:13 PM
jimmyb08SD's Avatar
Same on mine, it works just fine.
Old 04-14-2011, 08:43 PM
ns_redneck's Avatar
ns_redneck ns_redneck is offline
ns_redneck is starting off with a positive reputation.
it took me a few days to get used to it. but i don't mind it now.
Old 04-15-2011, 08:29 AM
Thanks for the education session. Now I don't mind it at all. Works just as you say.
Ford explorer turn signal lever not working Tinker bell Explorer, Sport Trac, Mountaineer & Aviator 12 10-11-2016 07:08 PM
Windshield washer button on turn signal lever slaponte 1997-2006 Expedition & Navigator 1 03-26-2016 02:00 AM
GM Steering Column in my Ford - But,, its not HunterSThompson General Automotive Discussion 4 08-21-2015 11:47 PM
Turn signal issues on 91 f150. Krisverde 1987 - 1996 F150 & Larger F-Series Trucks 1 08-06-2013 11:06 AM
Early 80's Ranger with horn button on turn signal lever av8r210 Ranger & B-Series 13 04-18-2011 09:56 PM
Tags
1948, 2008, 2009, 2011, blinker, blog, ecoboost, expedition, f150, fan, ford, lever, mileage, shut, signal, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
