5.0 vs 5.4
5.0 vs 5.4
2009 5.4 XLT Reg Cab Long Box 4x4 3.55 Limited Slip 7200lb
2011 5.0 XLT Reg Cab Long Box 4x4 3.75 Limited Slip 8200lb
Fuel Mileage on the dash 18L/100km with the 5.4 which is reading low cause if you figure it out yourself its 19L/100km!
The 5.0L reads 14L/100km on the dash and will need to be checked out cause its going through more gas then that I'm sure.
The 5.4 does have aggressive Load range E 265/75/16 tires
The 5.0 has the factory not so agressive 245/75/16 tires
The 5.0 likes to be reved and reved high! it revs higher then the 5.4 but it doesn't give the feeling like it will last for high milage like some of our past 4.6L and 5.4L to bad the 6.2 wasn't offered in the XLT
Anyone notice a oil drop in there 5.0?
18L/100Km would be around 13mpg
14l/100Km would be around 17mpg
So the 5.0 is getting better FE
Fordteamone
2015 - 2020 F150
15
01-06-2015 06:14 PM
640 CI Aluminum FORD
2009 - 2014 F150
38
01-18-2011 04:53 PM
