O.K. I found the Ford part numbers for the 4 inch rear blocks. Are they correct?
F81Z-5598-GA
F81Z-5598-FA
Second does anyone have the correct number for the U bolts that I'll need. Have been unable to find it on here.
The parts guy at the dealer was not much help either. Thanks in advance,
Will-
I would imagine so, if your using the blocks you would want the U bolts also, Im not sure if the 250 and 350 run the same or not.
Do yours have enough thread to add 2 more inches?
