1996 F-250 Instrument Cluster Issues - Ford Truck Enthusiasts Forums
Old 04-14-2011, 08:00 AM
fbavaro1's Avatar
fbavaro1 fbavaro1 is offline
fbavaro1 is starting off with a positive reputation.
A couple days after replacing the voltage regulator, my instrument cluster started acting weird. The volt meter stays pinned at the minimum reading, the gas gauge never reads a full tank and the temp gauge reads hot. Is there some central place to start looking? or could it be the computer?
Old 04-14-2011, 09:31 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
The computer has nothing to do with those gauges. Go back and check your wiring.
It may be coincidence but perhaps the gauge cluster connector on the back is starting to to get loose. My '92 F350 exhibited the same issue with the voltmeter and temperature gauge. I started to pull the dash to change the meters when I found the connector on the back just about ready to fall out.
Typically if there is an open in the fuel gauge circuit it will read way past Full. If the connector was loose perhaps it may read empty because there is no open length of wire acting as an antenna to pick up induced voltage?
Old 04-14-2011, 09:46 AM
fbavaro1's Avatar
I forgot to mention. The overdrive button on the shifter also does not function.
Old 04-14-2011, 10:13 AM
rla2005's Avatar
All this started failing after you replaced the voltage regulator?
Old 04-14-2011, 10:30 AM
fbavaro1's Avatar
Yes, a couple days after. And it was all at once. The regulator was over charging where the lights would get real bright and the engine would run like crap and produce heavy gas fumes. I figured there was too much gas due to the higher voltage. Perhaps that caused some damage somewhere???
Old 04-14-2011, 10:51 AM
rla2005's Avatar
It's possible that could happen. Again the computer does not control the gauges, but there is interaction with the overdrive switch and light.
There is a fuse for the O/D switch and light, my 1994 EVTM shows it as Fuse 17 but that may be different for your '96. I also see that same fuse supplies power to the instrument cluster as well.
Old 04-14-2011, 12:00 PM
fbavaro1's Avatar
That was it. Fuse #17. All is good now. Thanks for your help.
Old 04-14-2011, 12:49 PM
rla2005's Avatar
Excellent! Glad to see you found it.
Old 04-14-2011, 06:39 PM
slowjack's Avatar
slowjack slowjack is offline
slowjack is starting off with a positive reputation.
Are you serious? A blown fuse fixed it? You must be blessed my friend and hopefully some day we can meet and you can do the "laying of the hands" on my truck, please! I mean I have never had anything fixed by merely replacing a fuse.
Jack
74 Instrument Cluster Questions Tiggie 1973 - 1979 F-100 & Larger F-Series Trucks 6 12-22-2016 12:50 PM
Instrument Cluster Problems.... GRNMSTR 2004 - 2008 F150 3 06-04-2016 08:33 PM
1997 F 150 instrument gauge cluster mchittester 1997 - 2003 F150 3 09-28-2013 05:06 PM
'95 Instrument Cluster Swap Questions Nathan Plemons 1987 - 1996 F150 & Larger F-Series Trucks 7 06-14-2013 02:56 PM
Instrument cluster lens COLMISS 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-21-2008 09:25 PM
Tags
1994, 1996, cluster, dash, diesel, f150, f250, ford, gage, instrument, insturment, issues, light, pannel, problem, series, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
