Need help '96 2.3
Need help '96 2.3
I have a '96 2.3 runs great for about 35- 40 minutes, quits just like you turned the key off. If you let it sit about five or ten minutes it starts up and runs like nothing is wrong and runs five or tens minutes and quits again. If you let it sit overnight, its good for the 35-40 minutes. I get the same two codes everytime it quits, P103 and P1121, I replaced the MAF senor assy and the PCM no help.
I've fought this problem for about a month, even took it to Ford dealer.... other than costing me too much money, nothing changed.... ideas anyone???
I think the ICM is right behind the AC compressor. if it is Metal it is probably the original and it could be your issue. even if it is plastic it could still be your issue. you can take it off and have it tested at the stores. have them test it a bunch of time. make sure you put every screw back that you take out they are grounds. also next time it will not start spray starter fluid into the TB if it fires up it is a fuel issue. if it does not fire up check for spark.
Ranger update....... truck quit, this time would not start back up even after sitting overnight. Thought about replacing ICM......'96 2.3 it's built in the PCM, so I replaced the crank position sensor...... about the only thing I haven't replaced. Ran great, drove around about forty five minutes no problems.... started home and it quit again about fifteen miles from home. After the three of the normal five minute rest stops on the side road, it decided to run again...... after about an hour of short trips close to home I called it a day.....
Some of the ICM's were located on intake manifold and subject to fail due to heat.
| Repair Guides | Distributorless Ignition System | Ignition Control Module (icm) | AutoZone.com
maybe they moved it off the intake manifold(behind the AC compressor) in 1996........look on the fender wells away from the engine. see f you can follow the wires from the coil pack or else post a new thread asking "were is the icm on my 1996"......I know you have one........good luck..........it could also be a bad coilpack you can test them also........i
I dunno where it is, but I know where it ain't, and that's on the intake behind the A/C compressor. Had that off just a few days ago.......
1995PSD
05-16-2009 04:00 PM
Bigben111
07-29-2004 08:25 PM
