4x4 module on 2002 explorer xls
Hey guys listen i have a problem.I went to my mechanic and he told me i needed the 4 wheel drive module for my 2002 ford explorer xls.I have had the truck for awhile now and the 4x4 has never lit up in the dash.Is the module a dealer part only?Is there a site online where i can buy this part.And what is the part number,thanks i could really use some help here.
https://www.silverstatefordparts.com/contact.html
That's where I got a new module for my '02 XLT a few years ago. It's the online side of a Ford dealership in Las Vegas. They were about half what the local dealer wanted for one and a snap to install - plug and play really. Send them an email from that link and ask for a quote. Be sure to include your VIN in the email so that they can get you the correct updated part number. There is a difference between early-build and late-build models in 2002. They can tell from your VIN which one you need. Post back and let us know how you make out.
Good luck.
Good luck.
If you squeeze the sides of your glovebox together and pull it forward this is what you will see:
To do the swap you should first disconnect the ground clamp from the battery.
The module is held in place by a bracket. Take out the screw circled in red and the bracket will come out. It's much easier to get to the back screw if the bracket is off. Unscrew the module from the bracket.
Now just swap the connectors from the old module to the new one. Screw new module to bracket and install the bracket. Hook up the battery and try it out. Be careful on pavement in 4-High because it will want to bind up the front axles.
lmarkie
05-04-2017 09:00 PM
lmarkie
03-23-2017 06:56 AM
85MOTORSPORTXLT
03-18-2017 11:52 AM
eberf
02-01-2017 12:32 PM
kenpobuck
07-21-2016 07:10 PM
