4x4 module on 2002 explorer xls - Ford Truck Enthusiasts Forums
Old 04-13-2011, 09:00 PM
vid33nyc1 vid33nyc1 is offline
vid33nyc1 is starting off with a positive reputation.
Hey guys listen i have a problem.I went to my mechanic and he told me i needed the 4 wheel drive module for my 2002 ford explorer xls.I have had the truck for awhile now and the 4x4 has never lit up in the dash.Is the module a dealer part only?Is there a site online where i can buy this part.And what is the part number,thanks i could really use some help here.
Old 04-14-2011, 12:39 AM
rrgone rrgone is offline
rrgone is starting off with a positive reputation.
https://www.silverstatefordparts.com/contact.html
That's where I got a new module for my '02 XLT a few years ago. It's the online side of a Ford dealership in Las Vegas. They were about half what the local dealer wanted for one and a snap to install - plug and play really. Send them an email from that link and ask for a quote. Be sure to include your VIN in the email so that they can get you the correct updated part number. There is a difference between early-build and late-build models in 2002. They can tell from your VIN which one you need. Post back and let us know how you make out.
Good luck.
Old 04-14-2011, 11:15 AM
ok thanks alot.I sent them an email with my vin and im jusy waiting for a reply.
Old 04-14-2011, 01:33 PM
ok i spoke to them on the phone and i also got an email reply.they have the part so i will order online when i get home.correct me if im wrong but is the module located under the glove box somewhere?thx again saved me a ton of money.
Old 04-14-2011, 04:55 PM
If you squeeze the sides of your glovebox together and pull it forward this is what you will see:
To do the swap you should first disconnect the ground clamp from the battery.
The module is held in place by a bracket. Take out the screw circled in red and the bracket will come out. It's much easier to get to the back screw if the bracket is off. Unscrew the module from the bracket.
Now just swap the connectors from the old module to the new one. Screw new module to bracket and install the bracket. Hook up the battery and try it out. Be careful on pavement in 4-High because it will want to bind up the front axles.
Old 04-14-2011, 08:14 PM
Awesome thanks.Placed my order and will post the results after i receive and install it.
Old 08-15-2011, 10:02 PM
Jitterbug Jitterbug is offline
Jitterbug is starting off with a positive reputation.
how much was the part?
upper or lower intake gaskets kenpobuck Explorer, Sport Trac, Mountaineer & Aviator 1 07-21-2016 08:10 PM
2002 third seat installation??? Jleas524 Explorer, Sport Trac, Mountaineer & Aviator 5 01-14-2013 09:04 PM
2004 Ford Explorer XLS Rwing21 Explorer, Sport Trac, Mountaineer & Aviator 4 03-03-2006 01:21 PM
Tow hitch for 2002 Explorer Rick_M Explorer, Sport Trac, Mountaineer & Aviator 1 04-28-2004 06:25 PM
2002 Explorer XLS Compass and Trip Odometer knuckles Explorer, Sport Trac, Mountaineer & Aviator 5 01-25-2004 09:48 PM
Tags
200, 2002, 4x4, computer, decoder, disconnect, drive, explorer, ford, module, sport, trac, vin, wheel, xls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
