JP-8 Jet Fuel - Ford Truck Enthusiasts Forums
JP-8 Jet Fuel
Old 04-13-2011, 08:38 PM
LKCKR LKCKR is offline
LKCKR is starting off with a positive reputation.
JP-8 Jet Fuel
OK here's a weird question, I've been told that jet fuel would be OK to use in my 6.0 Powerstroke. Is it true and what are the conciquences good or bad?
Old 04-13-2011, 08:46 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
All I can say is you're playing Russian Roulette with a 15 grand engine. I wouldn't even ask the question.
Old 04-13-2011, 08:55 PM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
I may be crazy but i have heard everything the army has will run on JP8
Old 04-13-2011, 08:59 PM
XB70 XB70 is offline
XB70 has a good reputation on FTE.XB70 has a good reputation on FTE.
Jet A is selling for $5.45 per gallon in Southern California today. JP8 is the military equivalent.
Why would you even ask about using jet fuel in your truck at this price level unless some of it fell off the tanker truck? Since you're asking about JP8, do you have "access" to a military fuel tanker?
Old 04-13-2011, 09:01 PM
max6698 max6698 is offline
max6698 is starting off with a positive reputation.
why would even want to try and run jet fuel? I can tell you for sure and certain that you would have more than just exhaust coming out the tailpipe. I agree with 69cj 15K engine is a little to big of a chance
Old 04-13-2011, 09:06 PM
Lou Braun Lou Braun is offline
Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.
Some very good information from the Army's experience using JP8 as diesel fuel is listed in http://www.almc.army.mil/alog/issues...3;reality.html.
Basically, lubricity issues at high temperarure is a problem. Low termperature operation is OK.
Lou Braun
Old 04-13-2011, 09:11 PM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
That's not crazy at all. The move towards multifuel engines makes logistics sense and was done years ago. The standards for aircraft fuel are higher in terms of contaminants then motor fuel, and it has different additives.
JP-8 - Wikipedia, the free encyclopedia
When fuel is drained from civilian aircraft under some circumstances it is illegal to reuse for aviation, and lucky diesel owners who work at the right jobs can haul it off free to save HAZMAT fees. Otherwise it goes in the Safety-Kleen truck.
Check the powerstroke forums. Some folks run extra lube supplements or mix it with diesel.
Old 04-13-2011, 10:04 PM
Thanks guys I really wasn't seriously thinking about doing it, I am one of those lucky diesel owners that work at a job where I have access to JP-8 we drain from the F-22 Raptor when we pull the engines, some guys at work mentioned it and I wanted some clarification on the subject.
Old 04-13-2011, 11:22 PM
rdunagan's Avatar
rdunagan rdunagan is offline
rdunagan is gaining momentum as a positive member of FTE.rdunagan is gaining momentum as a positive member of FTE.
ive heard of it. ive heard that you get good fuel mileage and awesome performance! i have also heard of 8 MELTED pistons and turbos SHATTERING and things like that. but hey if you can make it work let me know ill start buying it from you IF you can make it safe!!
Old 04-13-2011, 11:55 PM
bradyracing bradyracing is offline
bradyracing is starting off with a positive reputation.
It will work. I've done it. I would run it as a blend and not straight. I get mine from an airport also when they drain it from planes. I may be the wrong person to ask though because I've run liquified styrofoam peanuts through my 6.0 just to see what would happen. It's all just one big expieriment so I don't care.
Old 04-14-2011, 12:03 AM
maxum96 maxum96 is offline
maxum96 is starting off with a positive reputation.
Jet fuel is the same as kerosene. A diesel engine will run on jet fuel, kerosene, motor oil, and other things. Jet fuel and kerosene are basically the same as diesel fuel. But they lack any oil for lubrication of the fuel injectors. So you'll probably destroy the fuel injectors, and on an engine with a mechanical fuel pump, you'll wreck the pump.
Old 04-14-2011, 12:52 AM
Mich6.0 Mich6.0 is offline
Mich6.0 is starting off with a positive reputation.
BE VERY CAREFULL WITH JP-8 IT BURNS AT A HIGHER TEMP THAN THE PREVIOS JP-4 OR JET A. IF YOU GET SOME ON YOUR SKIN YOU FEEL A BURNING SENSATION UNLIKE JP-4. WHEN JP-8 FIRST CAME OUT THE ARMY AND AIRFORCE BOTH HAD PROBLEMS USING IT IN THEIR HUMVES,LIKE SOME ELSE SAID THE MELTED THE MOTORS ON A COUPLE UNITS. THE REASON THE MILITARY WENT TO JP-8 IS THE HIGHER FLASH PIONT,NOW IF YOU CAN GET AHOLD OF THE PLUS 100 ADDITIVE IT WOULD CLEAN UP YOUR FUEL SYSTEMBUT NOT SURE IF THE INJECTOR ORINGS WILL LAST AS THE STUFF IS REALLY HARD ON STUFF. SO YOU WORK AT LANGLEY OR KIRLAND I SEE. GOING TO KIRKLAND NEXT WEEK ,SEEMS THEY ARE MOVING ANOTHER BASE THEIR DUE TO THE BRAK SHUTDOWN.
Old 04-14-2011, 02:11 AM
p-nut p-nut is offline
p-nut has a good reputation on FTE.p-nut has a good reputation on FTE.
Quote:
I was in the Air force, still work for the Air force and drive diesel govs every day. They dont stock diesel fuel. Only JP-8 and Mo-gas. Mo-gas is on its way out. jp-8 has been powering hummers, dodge ford and chevy bobtails and diesel engined support equipment for YEARS without any serious issue.
JP-8 has a lower flashpoint than diesel at 100 deg. Diesel has a flashpoint of 143ish degrees. Jet-a is the civilian equivalent of jp-8. They went to jp-8 because it was less flammable and less hazardous. Flammability and flashpoint are two very different things. The biggest problem with JP-4 that warranted an upgrade was non conductive fuel and the fact that it could build up its own static electricity when being moved through pipes and tanks possibly cuasing itself to ignite.
This excerpt is taken from a de-classified AF technical order and has been used in places such as Wikipedia.org and other places.
"JP-8 (or Navy JP-5) is used as a fuel for aircraft, heaters, stoves, tanks and by the U.S. military as a replacement for diesel fuel in the engines of nearly all tactical ground vehicles and electrical generators, and as a coolant in engines and some other aircraft components. The use of a single fuel greatly simplifies logistics."
They didn't have problems with it melting engines but it does cause premature wear of HPOP, injectors and exhaust valve seats due to low sulphur content and undefined lubricity conditions. The 6.5L turbo GM diesel used in hummers was not really affected by the change but for one thing, under very cold conditions the trucks were hard to start and idled roughly until the combustion chambers were sufficently warmed. The 6.2L was uneffected by the fuel. It also doesn't gel at low temps.
Old 04-14-2011, 02:22 AM
Quote:
Its not quite the same as kerosene. There is a lubricuty factor but isn't defined. Turbine engines have hydro-mechanical or auto-manual fuel controls that operate very similarly to the injection pump on a diesel engine. These parts dont wear out on turbine engines that often and mostly are chaged due to outside defects and not fuel lubricity.
Old 04-14-2011, 02:23 AM
deleted
Carb jets dwhawkins89 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 03-24-2016 04:28 AM
Trying to gain understanding of Carburetor Theory whisler 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 02-14-2016 11:54 AM
jets jets jets 1983 f150 302 v8 cubanice27 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-03-2015 05:42 AM
Carb Jet Thread Sizes Macs1964F100 1961 - 1966 F-100 & Larger F-Series Trucks 12 04-19-2014 12:39 PM
Jet size???? motor 272, carb Autolite 2100 292J C3TF-K jimcar-9 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 04-28-2008 02:02 AM
Tags
2005, 60, burning, buy, cost, f250, fuel, gallon, jet, jp8, maximum, military, powerstroke, reuse, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
