JP-8 Jet Fuel - Page 4 - Ford Truck Enthusiasts Forums
JP-8 Jet Fuel
  #46
Old 06-04-2014, 04:34 PM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
Quote:
Originally Posted by HT32BSX115 View Post
DON'T do it!
Think Kero mixed with gasoline............. Ask anyone here what happens to a 6.0L engine when you mix gasoline with diesel (gasoline mixed with K1 would be much worse IMHO since Kerosine has lower lubricity)
Sorry, I misspoke. I didn't mean I was going to run my 6.0 on JP-4 sooner or later. Just that I was probably going to experiment with fuels other than pump diesel sooner or later.
Quote:
I don't know where you'd get it anymore though. The USAF stopped using it in the mid 90's It was pretty much completely replaced by JP-8.
I used to have access to a ~10,000 gallon container of old, probably-will-never-be-used JP-4 that had been forgotten. Used to.
  #47
Old 06-05-2014, 10:45 AM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Quote:
Now that would be REALLY cool if it were kerosine or diesel!
  #48
Old 06-05-2014, 03:14 PM
Per4mance's Avatar
Per4mance Per4mance is online now
Per4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to all
Just add oil to it LOL
  #49
Old 06-17-2014, 03:47 PM
slowlanemcvane slowlanemcvane is offline
slowlanemcvane is gaining momentum as a positive member of FTE.slowlanemcvane is gaining momentum as a positive member of FTE.
I'm actually considering doing this. I work on Gray Army Airfield at Fort Lewis, and we take fuel samples during preflight every time we go up. Pull a quart of fuel out of the six tanks on our CH-47s, and it goes into a fuel sample station. If the aircraft lands and takes on more fuel, then the old sample is void and not suitable for putting back into the aircraft. I may take that fuel, pour it into a fuel can, and start using it diluted with pump diesel. Maybe 5 gallons per tank. I figure it's a free source of fuel, and it should work just fine when cut with pump diesel.
Hmmmmm...
  #50
Old 06-17-2014, 08:14 PM
Gurahl Gurahl is offline
Gurahl is starting off with a positive reputation.
According to the TM for our FMTV JP-8 is the tertiary fuel and the Army still runs it in all of it's tactical vehicles. We have an F-350 that we use for Conus EOD Response. When one of the new guys accidentally filled it with JP-8, our maintenance guys dropped the tank, cleaned it, and replaced all the filters before they would let us use it. Take it for what it's worth.
  #51
Old 06-20-2014, 02:55 PM
HT32BSX115's Avatar
Quote:
Hmmmmm...
Probably "ok" in an older rotory type diesel injection system mixed with some biodiesel, light oil, 2-stroke oil, etc.
I wouldn't put it in a HEUI or Common rail engine.
  #52
Old 06-20-2014, 03:00 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
If anything a HEUI is the most tolerant to fuel type being the actuation is done by engine oil and the fuel supply is constant pressure.
Mechanical injection, and common rail utilize far more complicated injection pumps and parts.
Josh
  #53
Old 06-21-2014, 09:12 PM
HT32BSX115's Avatar
Josh
I am thinking that HEUI injectors might be fairly sensitive to low lubricity fuel in the "fuel-side" of the injector, which might contribute to piston "stiction" .............Is that even a word?)
You're right though, that fuel injection pumps might be more susceptible to damage from lower-lubricity fuel.
  #54
Old 06-21-2014, 09:24 PM
Bullitt390's Avatar
The earliest 6.0 injectors suffered piston scarring, but the updated injectors with the DLC are more durable.
I have been curious about plunger "stiction"... It seems some failed injectors do suffer some form of that. Though I would likely blame low fuel pressure for it.
Josh
Headers and Carburetor Jetting LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 01-05-2017 07:28 PM
Trying to gain understanding of Carburetor Theory whisler 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 02-14-2016 10:54 AM
jets jets jets 1983 f150 302 v8 cubanice27 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-03-2015 04:42 AM
Carb Jet Wrench Macs1964F100 1961 - 1966 F-100 & Larger F-Series Trucks 7 01-20-2014 09:37 AM
Jet Fuel Florida F250 Bio-diesel, Propane & Alternative Diesel Engine Fuels 17 02-07-2007 06:14 AM
Tags
2005, 60, burning, buy, cost, f250, fuel, gallon, jet, jp8, maximum, military, powerstroke, reuse, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
