Big 6 Oil Pan Gasket
I have a 95 F150, 2 Wheel Drive, Single Cab Long Bed, with the Big 6 in it, and it needs an oil pan gasket done to it.
From what I understand its a pretty common thing for those motors to push oil pan gaskets out.
My question is, Can this be done without jacking the motor up, there is a crossmember right under the pan which makes dropping it to the ground impossible with out jacking the motor.
If I drop the pan will I have enough room to slide the gasket under the sump?
Thanks
Thanks
Just be sure it's the oil pan that's leaking. The driver side of this motor has a lifter cover. It's a dumb design, with 6 bolts in the CENTER of the plate. These gaskets are easily pushed out. The oil always runs down and drips off the pan. I learned this lesson the hard way, as i always saw oil dripping off of my drain plug.
-Wes
But I do agree, make sure it is the oil pan....The rear main could easily be dripping...
Thanks.
its the oil pan though it leaks out above the starter and onto my exhaust. Does the starter have to come off by chance? No big deal just wonderin. Im probably gonna do it this weekend.
Thanks again
Also how can i keep the gasket dry when going under the sump. I feel like no matter what some oil
Will get on the gasket
Thanks again
I don't remember having to take off the starter. I wouldn't worry too much about keeping the gasket dry as long as you are using the one-piece rubber gasket. Just be careful about it and keep it as dry as you can. Put a small spot of black RTV silicone in the corners where the pan rail on the block meets the hoops around the crankshaft and you should be in good shape.
Just a small little dab in the very corner where the flat part meets the hoop at each end of the block. The rest of the gasket should be installed dry (discounting a little motor oil -- it won't hurt anything). One more thing is to be sure to torque the bolts to the correct tightness. If you over-torque them it will push out the gasket and cause another leak. Just by memory, I think the spec was 100-120 in.-lbs. Others feel free to chime in if this is incorrect.
6.9 BLUES
04-02-2014 12:21 AM
dmacfordshot04
01-18-2006 04:41 PM
