Question about turbo cooldown...
So my mechanic brought up an interesting point as to why he hates trucks with the turbo cooldown feature, but I'm not sure about it either. I guess my question is do they have an override? His point was, if something catastrophic happens, is there some way to override the turbo cooldown to shut the truck off? He was saying that he had a truck come in that had this feature, and he didn't know how to shut it off, and it was a good thing it didn't have anything major wrong with it or he would have just had to sit there and watch the engine tear itself apart while it ran for 5-10 minutes.
Am i hurting something by using this feature?
Thanks
Hilgy
I actually figured most would have this feature because I knew the ones that come with remote starts do that, but apparently whichever one this specific guy had wouldn't do that because the guy at the shop said he tried everything he could think of. Also, I don't think it would be specifically for theft reasons because if the key isn't turned to the "run" position, it doesn't matter if you hit the brake or not, the shifter won't come out of park.
Yeah like Steve said, you're not hurting your truck. Getting the turbo really hot an then shutting the truck off wears on the turbo over time so the cooldown feature gets your egt's down and let's the turbo get down to a cooler temp before shutting it down.
A long time ago (like late 80's) the need for turbo timers went away....
like when good oils and good turbo's were put in trucks....
Even the oil mfgs say there is no need for them any longer.....
if you think about it how many times (probably none) have you been running such that the turbo was a t full boost and shut down within seconds ?
99 times out of a 100 you probably idled, or went slow on secondary road, or turned into the fuel station..... something to give 5 minutes of 'natural' cool down with air flowing across the system rather than idling sitting still....
but that's my soapbox diatribe for the day
SSN621
01-14-2002 06:26 PM
