grrrrrr. truck dead......again
trucks been throwing cel and simultaneously loosing power and just being a dog then completely dies.....have been able to start it back up and may be fine a mile or 2-3 days until yesterday. I had to be pulled home, had the exact same symptoms (cel came on, got real doggy like it was starvin for fuel or air then died) except when I start it back, it starts then dies immiedetly after..............any ideas
batteries tested good. i got a code for manifold pressure and ebpv. cant remember the numbers. also I did get one the other day for cps bank 5 something or another but i did pull batts. and charge and test them underload and truck is doing the same thing but not showing that code now. I'll try unplugging the icp but believe i tried that already with same results
if you are replacing the cps try and get the grey one from international it has a stronger magnet in it. They fail less often. At least in my experience. 0.02
sensor
I thought the grey one with the purple o-ring was the upgraded one? it is not the cps. I piddled with it as much as possible and still would start then die. I took it to a mechanic that a buddy recommended who is a powerstroke guy and he has it running and going threw it for me, seems to be a intermint. loop in the ecm
