1987 f150 stepside? - Ford Truck Enthusiasts Forums
1987 f150 stepside?
Old 04-13-2011, 12:37 AM
lamenytro's Avatar
lamenytro lamenytro is offline
lamenytro is starting off with a positive reputation.
Question 1987 f150 stepside?
Old 04-13-2011, 09:01 AM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
Yes, they are very rare. Only Ford called them a Flareside. GM had the Stepside.
1987 was the only year for a Flareside for the 1987 - 1991 models, and the very last Flareside to have steel fenders.
Old 04-13-2011, 10:01 AM
KevinGnWV's Avatar
KevinGnWV KevinGnWV is offline
The village idiot.
KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.
Looks like it's in pretty good shape. I'd like to have it. His other ad is a great looking truck as well. Though not as rare.
Old 04-13-2011, 10:05 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Originally Posted by LARIAT 85 View Post
1987 was the only year for a Flair side for the 1987 - 1991 models, and the very last Flair side to have steel fenders.
those fenders are fiberglass. Just like the 80-86 flaresides
Old 04-13-2011, 10:34 AM
KevinGnWV's Avatar
The village idiot.
Quote:
I've read that the reason they are rare is because in early 87 Ford used up the leftover 80-86 beds. Is there any truth to this or just speculation?
Old 04-13-2011, 10:52 AM
Quote:
They only made them ONE year. That is why they are rare
Old 04-13-2011, 10:56 AM
KevinGnWV's Avatar
The village idiot.
Yes I know they only made them in 87, but I was asking if they were in fact leftover beds from the previous model. Not that important, just curious.
Old 04-13-2011, 11:08 AM
ChristopherN ChristopherN is offline
ChristopherN is starting off with a positive reputation.
BUY IT NOW! THAT IS AN ORDER!!!
For 1500 you can't loose.
Old 04-13-2011, 01:53 PM
LARIAT 85's Avatar
NO, they are not leftover beds from 1980 - 1986. The wheel arches on the 1980 - 1986 version were squared. The wheel arches for the 1987 were rounded to match the front fender wheel arches. The 1987 Flareside came with the same rear bumper, tail lights, and "chain up" tailgate as the 1980 - 1986 Flareside.
From 1988 - 1991 you could only get the Fleetside box. The Flareside was brought back in 1992, but it was different than the 1980 - 1986 and the 1987 version with a different tailgate, different bumper, and more integrated tail lights.
I could indeed be wrong, as I have never seen them in person, but I always heard the 1980 - 1987 flare sides referred to as "old style" Flare sides, and the later 1992 Flare sides were considered the "new style."
Old 04-13-2011, 08:18 PM
lamenytro's Avatar
i want to so badly, but my parents say 2 trucks is enough
Old 04-14-2011, 06:09 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Those are cool. The beds aren't leftovers from 80-86 bucause the wheel well openings are different.
Old 07-13-2011, 04:42 AM
pc_owner pc_owner is offline
pc_owner is starting off with a positive reputation.
Wink You are correct
In 1992 they changed the beds again to the type below that have 100% fiberglass rear quarters, I just picked up this 1993 for $1,300 with a soft lower end knock.
Will be rebuilding the engine and doing a 4X4 swap under it.
I was told this truck was kinda rare because of the extended cab and flareside.
Old 07-13-2011, 08:22 AM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
not sure how rare the extended cab/flareside option is,I have one also. It would be nice if ford would have kept records of how many of each model they made,but I haven't found numbers that are model specific.
Old 08-18-2011, 02:24 PM
kosmo01 kosmo01 is offline
kosmo01 is starting off with a positive reputation.
Yes they are fiberglass. I have a 1987 F 150 4x4 Flareside, also have a set of earlier fenders that also fiberglass. I bought the earlier box for parts, then seen the fiberglass fenders are not the same. The 87's have a small flare above the wheel the others one don't
Check this out... Thought I'd seen everything till this Hillbilly63 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 01-15-2017 11:09 PM
53 F100 front 2001 Explorer body Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 09-03-2016 08:14 PM
WTB 1979 Ford F-100 Shortbed Stepside mcangelo4 New York Chapter 0 01-25-2016 11:41 PM
Sharp '87 Flareside FS in North Carolina SCFlareside 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-26-2015 10:08 AM
Ford 300 Carburator suggestions stepside1988 Ford Inline Six, 200, 250, 4.9L / 300 28 02-04-2011 01:23 PM
Tags
1987, 1990, 1993, 1995, 4x4, 50, air, code, engine, f150, flareside, ford, lariat, ram, side, step, stepside, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
