Turbo time
Old 02-10-2014, 06:37 AM
captfatboyf250's Avatar
captfatboyf250
captfatboyf250 is offline
Turbo time
Well found out why i blew off the hoses every time we kicked it down ... We be adding oil
<a href="http://s1067.photobucket.com/user/captfatboy/media/Mobile%20Uploads/094E4AD0-F22E-4672-9948-55B97FF54825.jpg.html" target="_blank"><img src="http://i1067.photobucket.com/albums/u429/captfatboy/Mobile%20Uploads/094E4AD0-F22E-4672-9948-55B97FF54825.jpg" border="0" alt=" photo 094E4AD0-F22E-4672-9948-55B97FF54825.jpg"/></a>
Old 02-10-2014, 06:42 AM
captfatboyf250
Guys should I go with the upgraded ball bearings or jus be happy with the brass
Old 02-10-2014, 06:46 AM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
Reroute the ccv hose instead.
https://www.ford-trucks.com/forums/7...-re-route.html
If you don't want to reroute the CCV, get some RiffRaff boots and clamps.
http://www.riffraffdiesel.com/riffra...el-products-3/
Old 02-10-2014, 07:08 AM
mustang_309's Avatar
mustang_309
mustang_309 is offline
That looks normal to me, its from the CCV as stated.
Old 02-10-2014, 07:22 AM
xaviar's Avatar
xaviar
xaviar is offline
I know the benefits of re-routing the CCV i.e.. ....oilly boots and intake. But, are there any known advantages to leaving it hooked up as the factory designed it? Does it provide any kind of cooling the intake charge (for example) or other benefit? Or, was it just a emissions deal for cleaner air? Thx.
Old 02-10-2014, 07:32 AM
captfatboyf250
Yes need to do that only thing is I've got play on this end.
Old 02-10-2014, 07:34 AM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
Its an emission deal. But it gums the turbo and intake. Leaves oil in your cac tubes and air charge cooler. Reroute it and it fixes it. To the op the oil looks normal. I would clean it up and clean all your boots up. I have used hairspray to help keep the boots on.
Old 02-10-2014, 07:48 AM
Money-Pit's Avatar
Money-Pit
Mostly an emissions thing....the combustion gases end up in the crankcase, and have to exit somewhere to prevent pressure build up on seals, etc. The factory routes it to the intake to be "recycled" basically. The result is higher intake temps, oil on all intake pipes/boots, inside intercooler, the intake itself, bla, bla, bla.
Old 02-10-2014, 07:50 AM
Money-Pit's Avatar
Money-Pit
Up and down.....or in and out?
https://www.ford-trucks.com/forums/9...haft-play.html
You can rebuild it if it's excessive.
https://www.ford-trucks.com/forums/1...ml#post9449262
Old 02-10-2014, 07:57 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Yeah, how much play?
Either way it's very rebuildable unless you want to upgrade...
Old 02-10-2014, 08:22 AM
captfatboyf250
Yes up and down I can just barely feel resistance when pushed to the side
Me thinks me got her ....just in time
Old 02-10-2014, 08:35 AM
run6.0run's Avatar
run6.0run
run6.0run is offline
The ball bearing turbos will eliminate the "turbo fart" when the throttle is let off suddenly FYI. I really think if the wallet allows it,, ball bearing is the way to go. But the ones I've had my hands on are non vgt,, so a custom tune will be needed also. Most turbo replacements go back with the journal bearings. Just some info. Oh,, I've got a journal bearing powermax on mine,, ball bearing turbos are about 3x the price.
Old 02-10-2014, 08:56 AM
Toreador_Diesel
Retired Mod
This is true...
My buddy had his powermax fail and he wanted to go with a Ball-bearing turbo. I explained what all is necessary and needless to say he let me rebuild his turbo.
It wil only cost $160 plus shipping to rebuild your stock turbo:
G-Pop Shop :: Garrett Rebuild Kit for Ford 6.0L Powerstroke |
This is the write up for it:
https://www.ford-trucks.com/forums/1...0-vgturbo.html
Old 02-11-2014, 01:55 AM
captfatboyf250
Originally Posted by Toreador_Diesel
This is true...
https://www.ford-trucks.com/forums/1... vgturbo.html
Question though
I see the up grade is a 360 bearing plate , which we ordered , but not a ball bearing for the shaft?
Just want to make sure we got b/b if that was a option
After all if your going to do,it do right
Thx
Old 02-11-2014, 04:56 AM
run6.0run's Avatar
run6.0run
The ball bearing cannot be achieved with our turbos. The only option to get b/b involves chunking our turbo and buying the whole b/b turbo assembly. Last one I had was a turbonetics,, and the turbo alone was $3k,, Before tuning, and any labor. It was a pricey mod.
Quick Reply: Turbo time
