Im having ac problems
Wild thought..perhaps the blend door is opening when driving(for whatever reason). This would allow for heat from the heater core to seep thru and give the expression the a/c wasn't working correctly.
Best idea I would suggest is to start the truck and with the a/c running and blowing cold, actuate the temp **** selector. See if there a complete motion and you can't simply pull it open when it's in the cold range.
The blend door itself could be malfunctioning or check the housing that holds the ac part near the firewall. It will be enclosed in a black 2-piece housing. It could be separating and while driving air entering the engine bay maybe blowing the housing opening and thus allowing for hot air to come in.
Great idea!
If ir doesn't return to cold when stop and/or sit idle, there could be a problem with the A/C itself. After starting the truck, visually look to see if the a/c compressor clutch engages when the A/C is cycling. Drive the truck and after you notice it getting warm, stop the truck, pop the hood and look to see if the clutch is still cycling. IF the clutch isn't cycling after you have been driving, best bet is to get some gauges on it as RLA2005 stated or get it to a reputable shop so they can further diagnose the problem.
When the A/C wasn't working on my ol' '92, the shop charged me about $175 for charging, replacing 3 O-rings, and a new low pressure side switch. I thougth this wasn't to bad since it was never serviced prior to my purchasing it.
Another possibility that has not been mentioned yet is an open water control valve - the vacuum-operated valve that controls the flow of water through the heater core (IIRC it is vacuum applied to stay closed, no vacuum means valve is open).
The air first travels through the A/C evaporator coil, where it is cooled and dehumidified, before traveling through the heater core. If the heater core has hot coolant flowing through it, the cold air will be reheated. This is desirable when you are trying to defrost the window, but not so much when you want to cool down the cab.
And when the engine is cold, the heater core is cold also, so this could explain the cold air at first and then none after the engine warms up.
