Will this starter fit my 7.3 IDI? - Ford Truck Enthusiasts Forums
Old 04-12-2011, 05:12 PM
oldblue89 oldblue89 is offline
oldblue89 is starting off with a positive reputation.
Starter 1988-1989 International 7.3 diesel eng - rblt | eBay
This looks different from the stock Mitsubishi starter, but it does say that it's for a 7.3 with a manual transmission, but for an international 1654 truck?
I have an 89 F-250 with a zf5 manual and 7.3 idi
Does anyone know if this starter will fit my truck? If not, why?
Thanks
Old 04-12-2011, 06:28 PM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
I'm going to cautiously say no. Reason: wrong bolt pattern
It's hard for me to tell from the ebay pics, but the 3 bolt holes look evenly spaced, where they should look like this>
EDIT: I'll say its wrong probably because of the SAE bellhousing that a medium duty truck like the 1654 would use with its manual transmission....
Old 04-12-2011, 06:59 PM
Fordownsall's Avatar
Fordownsall Fordownsall is offline
Fordownsall is starting off with a positive reputation.
yea I wouldn't risk it especially rebuilt, sounds a little squirrely, cant ever trust ebay. I spent I think it was around 130 for a brand new Bosch, and don't regret it at all.
Old 04-12-2011, 10:44 PM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
Yep the fords take a different starter and even ford had many different tooth counts on them over the years
Old 04-13-2011, 06:37 AM
Otahyoni's Avatar
Old 04-13-2011, 06:54 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i have the DB starter in my 88 also.
great price, fast shipping, and no core charge.
Old 04-13-2011, 04:56 PM
Happyreefer's Avatar
Happyreefer Happyreefer is offline
Happyreefer is starting off with a positive reputation.
i have a DB starter as well... I have pics of my new and old posted in my albums.
dido on shipping, service and quality
Old 04-13-2011, 05:00 PM
fast_st fast_st is offline
fast_st is starting off with a positive reputation.
It might fit the holes but that looks to be a direct drive starter. Most of the Fords use a gear reduction starter, either inline or offset that are much much smaller to fit in the cramped space. Outside of DB, find a local alternator/starter shop, usually you'll get a good price and often 1 hour turnaround if you need a rebuild.
Starter compatible ? Fasteddy83 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 07-06-2016 01:45 AM
transfer swap bigbird189 1987 - 1996 F150 & Larger F-Series Trucks 5 02-20-2015 09:30 AM
need help 1989 ford f super duty Xpebrian1 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 05-14-2013 10:49 PM
1968 f250 4x4; 7.3 diesel conversion? Eric Hagerman 1967 - 1972 F-100 & Larger F-Series Trucks 2 05-15-2012 07:47 PM
Starters - Manual vs. Automatic oldblue89 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 12-19-2010 03:43 PM
Tags
1994, 3, 60, 67, 68l, 69, 73, 91, aerostar, bolt, case, dodge, fit, ford, gear, idi, reduction, starter, starters, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
