HP / Torque of a 360??? - Ford Truck Enthusiasts Forums
Old 03-19-2003, 12:56 PM
nicebenz68 nicebenz68 is offline
nicebenz68 is gaining momentum as a positive member of FTE.
Question HP / Torque of a 360???
Hello again, Found out that the supposed 390 is actually a 360. Have searched the web for specs on a 360 but can't seem to find anything. Can anyone please tell me the stock horsepower and torque rating specs on a 1973 360 FE engine? I am considering replacing my tired 302 with a larger stronger engine to pull rather large enclosed trailers and need to know if I am wasting my time with the 360 / C6 combo.
Thanks again, Andy at Fort Hood, Texas
Old 03-19-2003, 03:57 PM
robertskunfused robertskunfused is offline
robertskunfused is starting off with a positive reputation.
i can tell you that the stock horsepower is around 215.i'm not to sure about the torque, i'm sure someone on here knows about how much it is. as for replacing the 302 with the 360, personally, i would do it if the 360 is not worn out. i think the 302 is too small of an engine to go in a truck, but it all depends who is wanting to do the swap. you could also consider the conversion to a 390. but get back to us as to what you are going to do with the engines.
Old 03-19-2003, 04:56 PM
I would definately prefer a 390 because I need to be able to pull heavy trailers with this truck. 215 sounds good as for HP if that is accurate. From what I here the HP on the 302 is right at 130HP so the additional HP will help. Torque is more important for towing though. The 360 runs smooth and strong without smoking. Selling the 302 when I can (does not smoke and runs well) but just not the strong engine I need for my towing needs.
Thanks, Andy at Fort Hood, Texas
Old 03-19-2003, 07:08 PM
460 Crew's Avatar
460 Crew 460 Crew is offline
460 Crew is starting off with a positive reputation.
68
the 360 is 215hp @4400rpm and 327lbs-ft@2600rpm and the
390 is 255hp@4400rpm and 376lbs-ft@2600rpm. I dont know about the 302. Hope this helps
1970 Crewcab 4x4 460 C6
Old 03-20-2003, 06:11 AM
macguyver macguyver is offline
macguyver is starting off with a positive reputation.
Remember, the 302's and the 360/390's have different bell housing patterns.
That said, either the 360 or 390 will make a much better truck engine than the 302.
Just my 2
Greg
Old 03-20-2003, 08:03 AM
Thanks! The HP of the 302 is 127HP from what I have been told so the 215HP of the 360 should be a great improvement. The 302 toruqe is 243 ft lbs so the additional from the 360 will work out too.
I already have a C6 tranny which came with the 360 (all for $150.00 "complete drivetrain") so bell housings are not a issue.
Just to tell what condition the 360 is in does anyone know the cranking compression readings would be on a 360? Just checking so that I can check that prior to installation and know what condition the engine is in.
Your information is greatly appriciated!
Thanks, Andy from Fort Hood, Texas
Old 03-20-2003, 11:32 AM
Rat wagon Rat wagon is offline
Rat wagon is starting off with a positive reputation.
125psi should be the cranking pressure for the 360,please correct me if I'm wrong
Old 03-20-2003, 11:10 PM
AbFitch Ford Boy's Avatar
AbFitch Ford Boy AbFitch Ford Boy is offline
AbFitch Ford Boy is starting off with a positive reputation.
Those HP and Torque ratings, are they the same for a '71 360 and 390? I would love to know just what the ratings are on my 390 F-250. It is a good strong motor and sounds great. Once you've had a 390 FE, you can never do without one!
Old 03-21-2003, 07:31 AM
460 Crew's Avatar
Abfitch
They should be the same I belive.
1970F250 4x4 CrewCab 460 C6
Old 03-21-2003, 09:42 AM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
Andy, did you see the end of this thread?
http://www.ford-trucks.com/forums/sh...hreadid=105645
Barry
rpm / torque graph for fe 390 / 360? eclectix 1967 - 1972 F-100 & Larger F-Series Trucks 16 09-04-2015 03:20 PM
1973 360FE 460jared96 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 06-01-2015 06:55 AM
360 Torque Specs Austy 1967 - 1972 F-100 & Larger F-Series Trucks 2 09-02-2013 01:04 PM
360 and 390 Horsepower and torque? 401477534 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 23 04-05-2011 11:45 AM
360 engine performance specs brider FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 04-07-2006 03:51 PM
Tags
1970, 1973, 360, compression, engine, fe, ford, good, hp, hptorque, readings, stock, stroker, torque, tq, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
