Turn Signals wont work
I noticed yesterday morning that my turn signals were not working on my 2000 F150 4.6L 4X4 XL truck and I need help Diagnosing what the cause is. The hazards, windshield wipers and my brights still work so I was not sure if it was just the switch. I have done the following and I am hoping that someone can help point me into the right direction.
* I went and got a new turn signal flasher at the parts store last night but when I went to put it in under the fuse box under the hood it was to big to fit into the holes. By this time the dealer was closed and I couldnt go and get a new one from them. (i wasnt sure if both needed to be replaced at the same time).
* Since there are two under the hood i just swapped the positions and still nothing happened everything worked accept my turn signals still worked. (by swapping I mean I took the one that was in fuse location 301 and put that one into 304 and 304 into 301.)
* I went to my owners manual and checked every fuse to make sure that anything related to my turn signals and flashers etc were not blown and they werent.
That is were I am at. Any help would be awesome. I dont think its the switch but is that a comon thing to go out?
Thank you
Thank you
The multi-function switch (MFS) is a pretty common failure item. I think most of the time the symptoms show up in the wiper delay. I have not read about a specific case where just the turn signals wouldn't work. Considering the troubleshooting you've already done, I'd say the there's a pretty good chance that the MFS is bad.
Thank you for the update Joe. After I got done posting this I googled the problem and I found an old thread that said that the wires inside by the steering column are pretty skimpy on length and if the steering wheel is tilted to far down then they may stretch enough to make the signals not work. It sounded crazy to me but I let someone borrow my truck this last weekend and I was sure they tilted the wheel down so I went and did that and they worked. Thanks again for replying to my thread I hope my exPerisnce can help someone else out.
The following users liked this post:
Turn Signals In-Op
Hello, It sounds like I have the same problem as you. My turn signals started out blinking a few times then stop. Now they are mostly inoperative. My hazards work and the way I understand it they use the same flasher. I found the relay and the flasher, when I move the lever either way I can feel the relay click once. This leads me to believe the switch is working so I was thinking a ground wire might be the problem. If possible could you be a bit more specific about the wire? I found that old thread as well but it was not very specific either. Thanks a bunch, Rob.
Artyoff
13
08-10-2012 06:10 PM
