406 heads - Ford Truck Enthusiasts Forums
406 heads
Old 04-12-2011, 03:28 PM
gthiboy gthiboy is offline
gthiboy is starting off with a positive reputation.
406 heads
I was wondering what a pair of stock 406 medium riser heads would be worth? this is the description of them I got...
" They appear to be in pretty good shape! I don't believe that they have ever been disassembled, so they will need hardened seats and guides of course, but he really was not asking too much for them."
thanks, kyle
Old 04-12-2011, 08:06 PM
DeepRoots DeepRoots is offline
DeepRoots is gaining momentum as a positive member of FTE.DeepRoots is gaining momentum as a positive member of FTE.
Not knowing.... I thought the 406 was done for before the medium risers came about.
Old 04-14-2011, 07:40 AM
FFR428's Avatar
FFR428 FFR428 is offline
Needsmorecoffee.
FFR428 has a good reputation on FTE.FFR428 has a good reputation on FTE.
C2SE-6090-B, C2SE-6090-C are 406 heads. Also the C3AE-6090-C has a version with spring cups and smaller chambers. They are low riser heads and use 1.65 ex and 2.02 intake valves. Alot of guys try to pass off the standard C3-C heads as 406 heads so be careful what you buy.
Odds of obtaining a 406 engine cheaply? havi FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 36 11-19-2015 08:23 PM
Anybody ever have a stock big Ford 406 or 427? less FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 04-13-2008 11:58 PM
Lincoln 406 FE boomer202 1967 - 1972 F-100 & Larger F-Series Trucks 14 01-07-2006 07:36 AM
428 or 406 heads on 390..worth it? 71 Muddbugg FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 01-10-2005 05:53 AM
406 heads RAILMAN FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 10-29-2000 03:39 AM
Tags
1963, 406, c2se, c2se6090c, c3ae6090c, diesel, engine, fe, ford, good, heads, recommended, sbf, wanted, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
