Starter will not turn off
Old 04-12-2011, 01:13 PM
dmilner1970's Avatar
dmilner1970
dmilner1970 is offline
Exclamation Starter will not turn off
Hello Folks, I have a 88 Ford F250 7.5L 460. 2 wheel. When I started the truck the starter would not turn off even though I backed the key out. I had to jump out and immediately remove the negative battery cable. I have had some issues with the Key Column and replaced the cylinder. Its always been tight to turn both to the on position and even harder to the position where the starter engages. Where do I start? Also, is there something I can do in the meantime to get my truck home.. its stranded at a local grocery story. Wondering if I can bypass the key ignition and have a temp push button to start the truck until i can repair it permanently. What wires do I need to remove from the solenoid.. Please help!!! thank you!!!
Old 04-12-2011, 02:58 PM
94BigRed's Avatar
94BigRed
94BigRed is offline
Its sounds like the solenoid may have just stuck. The two wires you need to cross are the two heavier gage wires on either side of the switch. It would probably be better to leave them on and use a curved piece of metal to short them. I used to have to start a mower this way.
If you do have to take a wire off, take off just the one that goes to the starter and touch it to the other one, that way the live one stays secure on the switch.
Old 04-12-2011, 05:04 PM
dmilner1970
Thanks! Well, I replaced the ignition switch and it still doesn't work. I will replace the solenoid again an see if that fixes.. If not then I have a bad short somewhere?
Old 04-12-2011, 11:43 PM
deeznuts822's Avatar
deeznuts822
deeznuts822 is offline
Smack that solonoid a few times. After market solonoids are garbage!!!!!! I would test for power on the lil wire with the key in run, But if you have that lil wire disconnected and the starter runs its the solonoid. I have seen the crap autozone sells stick on first use. I would try what big red suggested if whackin the solonoid dont work. You dont need a 10 lb sledge or anything just a few taps with a hammer not hard but easy
Old 04-12-2011, 11:58 PM
94BigRed's Avatar
94BigRed
94BigRed is offline
Yeah, those switches can be sticky at first. A short wouldn't cause your starter to stay on. But a messed up solenoid could stick it running, then stick in open position. I would definitely do the solenoid next.
Old 04-13-2011, 02:33 AM
drjoe171's Avatar
drjoe171
drjoe171 is offline
we had a f250 come across the field, the girl got out,
handed the key to dad, and a few minutes later,
I heard screaming that there was smoke coming out from under the hood.
The solenoid stuck just enough to smoke the starter
and melt a few wire.
new solenoid and starter fixed it.
my key switch is funky and loose, too but that wasn't it (apparently)
That was 3 years ago.
Old 04-13-2011, 08:47 AM
dmilner1970
Guys... That was it.. The Solenoid was bad.. Thank you so much!!
Old 05-04-2011, 03:54 PM
stngh8r's Avatar
stngh8r
stngh8r is offline
My truck starter stuck today. I guess its time to pick up a solenoid.
Sorry for your misfortune dmilner1970, but thank you for starting this thread. To all the knowledge base that posted, thank you as well.
Eric
Old 05-04-2011, 06:43 PM
stngh8r's Avatar
stngh8r
stngh8r is offline
update: So far so good, new solenoid restored normal operation
Eric
mcerchio
01-07-2020 08:05 PM
96halfton
05-28-2018 01:38 PM
KShults
1999 to 2016 Super Duty
10-04-2016 07:40 AM
Uncle Paul
05-22-2014 09:33 AM
Singing River Farm
18
01-25-2014 03:51 PM
Quick Reply: Starter will not turn off
