Radio removal on my 2003 truck - Ford Truck Enthusiasts Forums
Old 04-12-2011, 01:15 PM
Osideboy Osideboy is offline
Osideboy is starting off with a positive reputation.
Need help to remove old radio. What do I need and where can I get insructions?
Old 04-12-2011, 04:13 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
This is the tool it take to release the clips that hold it in.
You can make your own out of a coat-hanger.
New OEM Radio Stereo Release Tool/Tools Removal Key 2 | eBay
Old 04-12-2011, 09:16 PM
wgotthardt wgotthardt is offline
wgotthardt is starting off with a positive reputation.
YouTube - Ford Car Stereo Removal and Others
I recommend the $2 tool(s), they are spring steel with ends that snap in place to the correct depth, with a coat hanger you'll be fishing around...but yeah it'll work if you have an idea how the clips are situated.
Old 04-13-2011, 12:36 PM
artfd artfd is offline
artfd is gaining momentum as a positive member of FTE.
Exclamation
Quote:
On the other hand, if you don't know how the clips are situated, you may not get them to work properly. I found it easier to disassemble my dashboard, and I needed to do some other things behind it anyway. Once I had the dashboard apart, it was easy to see how the clips were supposed to work. If you have never seen them before, never worked the tool, it may not work for you. Good luck.
Old 04-13-2011, 10:44 PM
Thanks I was able to get a tool from e-bay, and I also watched the vedio to see how it is done thanks to everyone who helped.
Old 04-13-2011, 10:45 PM
Thanks for your help I am able to switch out my radio.
Old 04-14-2011, 03:10 AM
phil6608's Avatar
Good job.
I need to get one myself.
I about broke something the last time changing my radio without it.
I'll never do that again,,soooo much easier with the tool!
Old 04-14-2011, 05:04 PM
What is a (DIN)
I have read where people talk about a DIN or double DIN and I ask myself, what the heck are they taking about? I have an idea it has to do with radio equipment, but don't have an idea.
Old 04-14-2011, 06:21 PM
phil6608's Avatar
Old 04-21-2011, 11:16 PM
chopped&dropped's Avatar
chopped&dropped chopped&dropped is offline
chopped&dropped is starting off with a positive reputation.
Oside boy DIN is the normal size of a radio
DOUBLE DIN is the thickness of 2 radios
id suggest you pull ur radio out and if the back comes out a little bit then dips down then you will know you have a din and a half let me know if you have anymore questions and i can see some pics
Remove dash to remove radio? MRCSUSN2007 1987 - 1996 F150 & Larger F-Series Trucks 3 01-10-2014 09:14 AM
Free Radio Removal Tool A/Ox4 1999 to 2016 Super Duty 0 06-20-2011 07:33 PM
Dash Trim Removal To Access Radio? dfooch 1999 to 2016 Super Duty 8 08-24-2010 11:25 PM
Radio removeal Boonebird 1994.5 - 1997 7.3L Power Stroke Diesel 20 04-02-2008 08:08 PM
How to Remove Radio in 1996 F-250 PickSty 1987 - 1996 F150 & Larger F-Series Trucks 6 04-16-2004 11:07 PM
Tags
19972003, 2003, f150, ford, radio, removal, remove, truck, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
