Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.7L Power Stroke Diesel 2011-2012 Ford Powerstroke 6.7 L turbo diesel engine SPONSORED BY:
  #1 (permalink)
Old 04-12-2011, 12:11 PM
thejean's Avatar
thejean thejean is offline
Garage is empty, add now
thejean is starting off with a positive reputation.
Question WDH - Do I need one?
Hi, I read on some random website that because the new F350’s have longer leaf springs that a weight distributing hitch is required. I plan to tow an enclosed race car trailer (about 9000#) and possibly a 30-40 ft camper (which I haven’t purchased yet so don’t know the weight) with my F-350 SRW diesel. I currently have a 600# rated WDH that I had for my V8 Pathfinder but now with this truck, I am not sure that it is required or even if a 600# WDH is adequate. I have a guy who wants to buy my 600# WDH this evening but not sure if I should keep it or not. What would you guys suggest? Also note that I would prefer to have an easily height adjustable hitch for using various trailers and my WDH is adjustable, but not 'easily'... at least not like an adjustable aluminum hitch. Thanks! JC
  #2 (permalink)
Old 04-12-2011, 12:45 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is offline
2011 Ford F-350
EpicCowlick is a splendid one to beholdEpicCowlick is a splendid one to beholdEpicCowlick is a splendid one to beholdEpicCowlick is a splendid one to beholdEpicCowlick is a splendid one to beholdEpicCowlick is a splendid one to behold
I had the same question when ordering this truck. I had a 25' tag trailer that I pulled with an Excursion for a few years. It really needed the Equalizer hitch or would weigh down the rear of the trailer a lot. It was also really helpful for the anti-sway features. Wasn't sure if the F350 would even need it. Bottom line, it's not absolutely required on the F350 but it is nice to have. The F350 has plenty of capacity but the trailer still sagged the rear a bit. And without the friction bars, I could feel the trailer moving around some. Once I matched the Equalizer to the F350 and the trailer, it was solid and confident. I say if you plan to tow any distance at speed, the WDH is still beneficial on the F350.
__________________
2011 6.7L CC SWB w/315/60/20 Toyo MT's
2" leveling kit/Rancho 9000XL shocks & dual stabilizer/B&W Hitch/Firestone Ride Rite Airbags/Air Lift Wireless On-board compressor/Viar on-board compressor & train horn/Titan 50 gallon tank/Line-X Bedliner/Door Seal Mod
  #3 (permalink)
Old 04-12-2011, 01:18 PM
Great Danes's Avatar
Great Danes Great Danes is offline
Great Danes is starting off with a positive reputation.
I agree with what Epic said, but I would sell the WDH that you currently have and get one that is more suited to the weight of the trailer. Remember, your tongue weight is gonna be 10-15% of the trailer weight, so for a 9k trailer you should have a WDH capable of at least 1000lbs. The anti sway friction bars are also important if you want a comfortable ride.
Before I had the trailer in my signature, I had a bumper pull toyhauler that weighed about 8500lbs and the WDH made a big difference! Without it, the truck sagged quite a bit more than I expected!
Just my $0.02
__________________
Cheers,
GD
2011 F350 Lariat CC 6.7L PSD - Limited Edition Seats
2010 Fuzion 302 Touring Edition II
  #4 (permalink)
Old 04-12-2011, 01:45 PM
jack_pine's Avatar
jack_pine jack_pine is offline
jack_pine is starting off with a positive reputation.
I guess my answer is why wouldn't you? For me it adds another layer of safety, especially the anti-sway part. I have it on my '04 6.0 pulling a 31 ft TT.
It is solid as a rock even in windy conditions. I will move to the '12 in the fall.
__________________
The constitution, It's not just a good idea...it's the law.
2012 SD 6.7 SRW LB 4*4 Current
2004 SD 6.0 SRW LB 4*4 Traded
2001 SD 7.3 DRW LB 4*4 Traded
  #5 (permalink)
Old 04-12-2011, 02:04 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
2003 Ford F-350
Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.Maxium4x4 has a spectacular reputation.
The truck can be rated to pull or haul the load, the WDH makes the rig more stable. Just think of a long bridge with no sag in the middle.....
__________________
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=209298&.jpg
John
Read First FTE Guidelines ULSD Click Here
2003 F-350 Reg Cab 6.0L
  #6 (permalink)
Old 04-12-2011, 03:18 PM
thejean's Avatar
Thanks for the advice fellas. Turns out that because I have a Reese WDH, all I need to do to bump up the rating is buy the 1200# bars for $200. Score! Luckily I even bought the extra long drop so I can accomodate the F350's taller stance. Double score!!
Tags
2011, 50, air, bags, diesel, equalizer, euilizer, f150, f350, flex, ford, forums, hitch, hybrid, wdh
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
