Is EGR a must?
Sorry, but first I don't believe any of these trucks came stock with a 400... Not this year range anyway. However, I am not an expert in these trucks. EGR from my understanding (reading here) will learn out your mixture at cruise, which helps to reduce the gas flow needed, resulting in better mpgs. That being said, I believe its possible to remove them and then mess around with your timing to just until it starts to ping and back it down.
Thats what i thought, i just wanted to be sure. Ant thoughts from anyone else?
You'll need the correct manifold to reinstall the EGR; mine is the Performer 400 EGR
which hs the necessary plumbing from the heads up tot he carb for the EGR:
Notice the small oval-sized hole above the two larger ones. I have no idea what the 2V
EGR spacer plate is there for.
The M-block engines (351M, 400) began life in the early 1970s in large sedans, their
Bronco lives in the mid-70s, in these trucks in, um, must have been 1980, I think the 70s
trucks were still using the 360s & 390s FE-series engines. The M blocks were phased
out in 1982.
M-Block 351M/400 History
If it came with a 400 from the factory, the VIN code (7th or 8th place, i forget) is a Z.
The rest of the engine is designed to be used with the EGR and its related devices &
plumbing all in place; without it, you will likely need to play with your ignition timing
and/or distributor's timing advance curve to keep it from pinging under load.
out in 1982.
on
351M and 400 engines were an option between 1977 and 1982.
There is also a rare 255 V8 that was offered for two years that was quite frankly awful.
The EGR is a emissions device. It can have MPG saving side effects though. That and a stock engine is calibrated to use it.
I agree with Franklin, using a aftermarket carb and intake would negate the need. although retiming and adjusting the timing curve may be needed.
out in 1982.
out in 1982.
for a while. There is no way it'd legitimately pass that test without one.
But I *did* buy the 4V EGR plate (Edelbrock #8053) to install and at least make it appear
that one is installed in the event I need to pass an Emissions test again.
I should also mention that I totally rebuilt my engine.
You could get the non-EGR Performer 400 and that EGR plate to install beneath your
carb, hook everything up so that it appears to be installed and functional.
But I'll bet you'll still need to pass the sniffer test....
