Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-11-2011, 07:13 PM
Bryan03 Bryan03 is offline
Garage is empty, add now
Bryan03 is starting off with a positive reputation.
Rear power quarter windows noise
Hi Everyone,
I have a 2007 EB Expedition with the power quarter windows. I intermittently have a wind/ vibration noise from the right rear quarter window. It mostly occurs when it is hot, at highway speeds with the air conditioner fan on higher speeds. Needless to say, i am pretty sure it is from the air trying to escape through the window. When it has done it at idle, I can press on the window from the outside and stop the vibration. Opening and closing the window does not change anything. Is there an adjustment to tighten the window so it closes just a little tighter against the weatherstripping?
Thanks in advance,
Bryan
  #2 (permalink)
Old 04-16-2011, 11:18 PM
Hemlock10's Avatar
Hemlock10 Hemlock10 is offline
2006 Ford F-350
Hemlock10 is starting off with a positive reputation.
I don't have the manual for this vehicle yet and I haven't had the pleasure of opening it up, but I did have the passenger quarter window freeze in the open position so I had to pull the power connector to see if it was the switch or motor. But I digress; I didn't see anything that looked like a mechanical adjustment and could only imagine that the motor would need to be shimmed to tighten the closing force. Again, without manuals or actually removing the motor myself put that in the "for what it's worth" catagory.
  #3 (permalink)
Old 04-17-2011, 08:27 AM
Thanks Hemlock10,
I did not see any adjustments either when I looked at it. I did not even think of shimming but that that is a good thought. I went ahead and ordered a manual off of ebay and will see if it shows anything different.
Thanks again,
Bryan
Tags
2006, 2011, expedition, ford, power, quarter, rear, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
