Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-11-2011, 06:16 PM
smash fascism's Avatar
smash fascism smash fascism is offline
Garage is empty, add now
smash fascism is starting off with a positive reputation.
EBPV gutting
After you remove the housing is there a gasket between the housing and the exhaust housing that I will need to replace? I have also read threads about gutting this and some show cutting of the pedisol. Just curious why this is being done? It shows some kind of actuator being removed from the pedistol.
Im going to be doing this mod this week and want to make sure I have all the parts I will need.
Thanks, Matt
__________________
1997 Ford F350 PSD, DIY 6637 Intake, 4in Exhaust, Built Trans With Billet Torque Converter, FPR Shim, Tonys Tunes 6 Pos, Triple A Pilar Gauge Pod, 33x12.50 On Mickys,
  #2 (permalink)
Old 04-11-2011, 06:27 PM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a very good reputation on FTE.427 fordman has a very good reputation on FTE.427 fordman has a very good reputation on FTE.427 fordman has a very good reputation on FTE.
There is no gasket in there iirc. I did the pedestol mod on mine, I removed the actuator and the cylinder as you mentioned and welded the holes up. You can just remove the actuator and put a pipe plug in there but it's still hard to get to that one turbo bolt. Lots easier to remove/install turbo without that thing on there. It is aluminum so if you do it you need to know that. I'll see if I can find a link for you.
__________________
Darin I BLEED BLUE 76F250 66 fairlane dragcar514
1997 F250 HD 7.3,3.55-4.10 swap done,156k,140VIDM,HPX, 3-4"tymar w 4"straight pipe,ccv mod, S366 turbo, DIY 6637, elec. fuel,rosewood stage ones,php tunes,T500 HPOP,180 tstat,6.0 fan,6.0IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and triple disc billet converter, upgraded trans, F550 leaf springs,mean green alternator and starter,SD dual tensioner upgrade, cold ac mod
  #3 (permalink)
Old 04-11-2011, 06:28 PM
http://www.ford-trucks.com/forums/91...t=ebpv+removal
I did the one gobstopper did.
__________________
  #4 (permalink)
Old 04-11-2011, 06:32 PM
redman84's Avatar
redman84 redman84 is offline
2006 Ford Explorer
My Garage
redman84 is gaining momentum as a positive member of FTE.redman84 is gaining momentum as a positive member of FTE.
I pulled the housing, cut out the valve, and plugged the hole. Three 12 point bolts holding it on IIRC. I want to do the pedestal as well but haven't had the desire to get in there and fight those dang bolts.
__________________
Jacob
1996 F-250 Ext Cab XLT 4x4 7.3L PSD: DP Tuner PCM, E4OD-->5 spd, Valair clutch, 3.55 LS, Rosewood stage I's, IDM-120, FPR shim(65 PSI), 6637, no EBPV, 3" DP, gutted kitty 200k
2006 Explorer Eddie Bauer 4.0L 5r55s K&N 99k (hers)
MOΛΩN ΛABÉ
  #5 (permalink)
Old 04-11-2011, 07:28 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
1996 Ford F-250
RÖENTGEEP is a name known to allRÖENTGEEP is a name known to allRÖENTGEEP is a name known to allRÖENTGEEP is a name known to allRÖENTGEEP is a name known to allRÖENTGEEP is a name known to all
Exclamation
Thanks, Matt
IF you remove the pedestal, for sure you will need two of this o-rings for it:
Turbo Pedestal O-Rings (between pedestal & block; pedestal & turbo)fficeffice" />>>
(Ford) F4TZ-6N653-A & F4TZ-6N653-B
(International) 1815560C1 Turbo to pedistal O-ring .421 x .560
(International) 1815561C1 Turbo to pedistal O-ring .769 x .908
__________________
96 F250, E40D, 2WD, 3.55, 145K. DIY intake-exhaust brake. DP 3-3.5" ceramic coated; HPX; GPR switch; Isspro gauges; shim FPR; Tru-cool; CCV mod; 4" SS exhaust; SS 5" tip; no cat; RacerX VB; TW 6p chip; 203*;140IDM;6.0IC; cristal clear lenses.
«Primum non nosere» Drive safely !
  #6 (permalink)
Old 04-11-2011, 07:36 PM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
1996 Ford F-250
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
Pilgrim812
What is the advantage of gutting the EBPV?
__________________
Joseph
1996 F-250 XLT 4x4, "Heavy Metal", 7.3L Powerstroke, ZF S5-42 transmission with Valair clutch and flywheel, Supercab, 8' bed, Riffraff 6637, HPX, Dieselsite 203 degree thermostat, 3" Downpipe to 4" straight pipe exhaust.
"you are not a troll. a pain in the --- sometimes, but not a troll." - tjc transport
  #7 (permalink)
Old 04-11-2011, 08:06 PM
RÖENTGEEP's Avatar
FOREIGN GURU
1996 Ford F-250
Talking
Quote:
Less restriction (it blocks about a 20%), less EGTs.(20-50 IIRC) and if you mod the pedestal no oil leaks there in the rod and better work when unistall your turbo.
__________________
  #8 (permalink)
Old 04-12-2011, 12:27 PM
so there is no advantage other than easier turbo removal by cutting the actuator off correct?
__________________
  #9 (permalink)
Old 04-12-2011, 02:42 PM
not really, just sooo much easier to do the turbo and you don't have to worry about it leaking. Plugging it will not let it leak, but the turbo still sucks...
__________________
  #10 (permalink)
Old 04-12-2011, 06:41 PM
RÖENTGEEP's Avatar
FOREIGN GURU
1996 Ford F-250
Lightbulb
Well is not just cutting the actuator you have to mod the pedestal. Luck the pics below (stock and after mod).
Quote:
X2 on that
__________________
Tags
1997, 2002, 250, 73, 96, ebpr, ebpv, ebrv, ford, gutting, modify, pedestal, powerstroke, turbo, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
