Econoline front disc brakes...is it possibl,e?
Old 04-11-2011, 04:38 PM
Pondbird's Avatar
Pondbird
Pondbird is offline
Buildingg 1961 Econoline, is it possible to install front disc brakes...is there a company that sells a conversion kit to accomplish this, or a donor vehicle?
Pondbird
Old 04-11-2011, 10:35 PM
66gpw's Avatar
66gpw
66gpw is offline
It is possible. I read on either here or Vintage vans. where someone was doing this. He had pictures of the power brake booster under the truck and disc brake conversion for the front axle.
Another fella that has not been here for a while. Put a Jaguar car rearend in his truck. It worked great and they have disc brakes for them also. He said those rearends are cheap over in England where he is at.
I check some of the sponsor sites that specialise on Econolines, I thinks it is Macs that has something to do a conversion.
Old 04-13-2011, 09:23 AM
Thomas_E_NY's Avatar
Thomas_E_NY
Thomas_E_NY is offline
Old 04-13-2011, 10:31 AM
66gpw's Avatar
66gpw
66gpw is offline
Here is a link to a site showing it being done.
61-67 Ford Econoline Disc Brake Install
Old 06-18-2011, 09:19 PM
j-md's Avatar
j-md
j-md is offline
another option is the AMC set up
Old 06-19-2011, 12:23 PM
j-md's Avatar
j-md
j-md is offline
Remember that the discs require different pressure than the drums ... ideally you should have a dual master and then a porportioning valve for the rear ... D&D Brakes sells a bracket that replaces the single set up and accommodates a dual ... OLDSKOOL actually has a remote resevoir kit for the 67 master ... you never have to pop the floor again ...
Old 06-19-2011, 12:25 PM
j-md's Avatar
j-md
j-md is offline
Thats the mingle set up ... I have it here ...
Old 11-16-2013, 10:56 AM
Ford 67 Ford's Avatar
Ford 67 Ford
Ford 67 Ford is offline
This is a nice straight forward disc set up. Later.
Old 11-16-2013, 12:07 PM
66gpw's Avatar
66gpw
66gpw is offline
I'm considering a Dodge Kframe set on one of mine Econo trucks. Have not got to that stage yet. But lke the idea of a nice soft riding front end with the torsion bars to adjust the height.
Dodge K frames come with all the control arms, Steering box and disc brakes. Just have to make a mounting points for the Kframe.
I just been too busy with other projects these years. But it is what 'm thinking of giving it a try.
Old 11-18-2013, 10:18 PM
Ford 67 Ford
That torsion front end would be slick. I really like the idea of wrenchin 2 bolts to lower.
Has it been done before, if so than could save some headaches.
I guess that would just be a bonus with the main reason being a better steering box and disks. Later.
Old 11-18-2013, 10:46 PM
66gpw's Avatar
66gpw
66gpw is offline
I don't know if done on Econoline van tuck. But it has been doe on a number of 50'strucks nowadays. Even rat rodders are fitting them onto old car frames of the 20's for nicer rides with V8 engines. Not so much for racing, more show.
Old 03-06-2014, 11:06 PM
green64's Avatar
green64
green64 is offline
Template
Does anyone have or know where to get a template of the caliper mount for the front axle? I like the kits out there but kind of pricey for what you get in some of them.
Old 05-14-2014, 05:35 PM
chopped50ford's Avatar
chopped50ford
chopped50ford is offline
Thumbs down
Thats a great page, but why didn't the installer put part numbers and pieces used.
Its proven it can be done, but useless to the rest of us unfortunately.
colormebad
05-11-2020 11:39 AM
leonharu
04-07-2017 07:12 AM
SummerBreeze2
27
11-11-2015 06:04 PM
BrockGrimes
07-10-2015 08:05 AM
shemp123
03-05-2006 01:12 AM
Quick Reply: Econoline front disc brakes...is it possibl,e?
