Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-11-2011, 04:38 PM
Pondbird Pondbird is offline
Garage is empty, add now
Pondbird is starting off with a positive reputation.
Econoline front disc brakes...is it possibl,e?
Buildingg 1961 Econoline, is it possible to install front disc brakes...is there a company that sells a conversion kit to accomplish this, or a donor vehicle?
Pondbird
  #2 (permalink)
Old 04-11-2011, 10:35 PM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
It is possible. I read on either here or Vintage vans. where someone was doing this. He had pictures of the power brake booster under the truck and disc brake conversion for the front axle.
Another fella that has not been here for a while. Put a Jaguar car rearend in his truck. It worked great and they have disc brakes for them also. He said those rearends are cheap over in England where he is at.
I check some of the sponsor sites that specialise on Econolines, I thinks it is Macs that has something to do a conversion.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
  #4 (permalink)
Old 04-13-2011, 10:31 AM
66gpw's Avatar
Here is a link to a site showing it being done.
61-67 Ford Econoline Disc Brake Install
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
  #5 (permalink)
Old 06-18-2011, 09:19 PM
j-md's Avatar
j-md j-md is offline
j-md is starting off with a positive reputation.
another option is the AMC set up
  #6 (permalink)
Old 06-19-2011, 12:23 PM
j-md's Avatar
Remember that the discs require different pressure than the drums ... ideally you should have a dual master and then a porportioning valve for the rear ... D&D Brakes sells a bracket that replaces the single set up and accommodates a dual ... OLDSKOOL actually has a remote resevoir kit for the 67 master ... you never have to pop the floor again ...
  #7 (permalink)
Old 06-19-2011, 12:25 PM
j-md's Avatar
Thats the mingle set up ... I have it here ...
Tags
6167, 64, 67, axle, brake, brakes, disc, disk, early, econoline, front, kit, swap, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
