Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Escape Hard Starting
Old 04-11-2011, 03:51 PM
56yroldkid's Avatar
56yroldkid
56yroldkid is offline
2001 Escape V6 issues are;<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
1. Usually will need to crank engine over 3 to 4 times before engine will start. This escape has between 120k & 160k miles. What could be the possible issues? <o></o>
2. Is there an alternate battery group to use for this car that is not so dang expensive? <o></o>
3. Horn has never worked on this SSUV. The location for the horn fuse has no contacts. <o></o>
4. Was the factory remote entry alarm connected to car horn or is there an auxiliary horn for the factory alarm.
Thanks for any help on this issue.
Old 04-12-2011, 09:28 AM
tomw's Avatar
tomw
tomw is offline
1)look at: a)leaky injectors, b)old spark plugs, c)leaky intake manifold gaskets, d)check valve in fuel pump allowing drainback leaving the fuel rail empty. Test for a & d by cycling ignition key from off to on to off half a dozen times, allowing the fuel pump to run and stop each time. That would insure fuel rail is full, then try to start. check c with carb cleaner or WD-40 sprayed around gasket areas. It would also idle poorly with a leaky intake.
check b by removing and inspecting if you don't know the age. Be aware plugs can take out the COP coil and the PCM in the worst case of misfire.
2)IDK, but a Delco 91-6YR can be crammed in to fit.
3)NAC
4)NS
IDK - i don't know NAC - not a clue NS - not sure.
Likely the horn is the horn is ... Why install and carry around 2?
tom
Rayil
1999 to 2016 Super Duty
82
08-14-2012 07:45 PM
TexasEX2K
07-05-2012 10:46 PM
Texas 6.0
05-24-2011 11:22 AM
samurai
07-03-2010 05:30 AM
Jrodz
35
08-21-2009 10:46 PM
Quick Reply: Escape Hard Starting
