1993 300 ENGINE MISFIRE PROBLEM - Ford Truck Enthusiasts Forums
Old 04-11-2011, 01:32 AM
emccamaro91 emccamaro91 is offline
emccamaro91 is starting off with a positive reputation.
i have a 1993 f150 xl reg cab 8foot bed with 197,000 5 speed. since january my truck would run good one day, bad the next. i notice this throughout all the gears by the way. what happens is at a certain point of the position of the pedal on the floor, the truck starts to misfire and run really rough, but not stall out. i have to push the throttle down to almost 3/4 in order for it to stop doing that, but it takes it about 2 seconds to realize that i pushed the throttle down. then it instantly gives it gas. Ive replaced the fuel filter and also the air filter, but still the same thing. all original parts.....
If anyone knows what is wrong, any advice would do. Thanks!
Old 04-11-2011, 09:28 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Finish your tuneup with new plugs/cap/rotor and plug wires.
Weird bucking/shaking copen93 1987 - 1996 F150 & Larger F-Series Trucks 2 02-02-2015 11:56 PM
1993 EB Bronco 5.0 Misfire - very Difficult MrWP819300 1978 - 1996 Big Bronco 28 06-14-2010 08:32 AM
Misfire/sputter at acceleration Broncoslocos Ford Inline Six, 200, 250, 4.9L / 300 10 06-23-2008 10:48 PM
P0300 - Random misfire with Roush blower FTE Ken Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 12 01-30-2008 01:29 PM
Misfiring Smokey0210 3.8 & 4.2L V6 2 08-04-2005 12:59 PM
Tags
1993, 300, 4x4, 50, 93, 94, cab, engine, explorer, f150, ford, misfire, miss, missfire, super, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
