which size tire will better for super e250?
my 87 e250 wheel is after market 16x7 but tire is LT235-85-16
pretty high body lift but door label say suppose be 215-85-16
but it wont fit in my garage 7 foot if i change tire to 225-75-16 will it look nice
and little low body? or use 215-85-16??
I have the same tire on my van (215/85X16). I think the 225/70X16 will lower it some but you would have to check the diameter of each tire to confirm how much.
A couple of things to note would be that your overall gear ratio will change which will reduce your fuel mileage a bit but the shorter tire will lower the vans wind resistance so thats a plus! This could be a wash as far as over all mileage.
does it pass under 7 foot?
Tires were installed by previous owner. The tires are a heavy duty tire at their load capacity is a bit over 3000 lbs when inflated to 80 psi. I usually keep them at 50 front and 60-65 psi rear when loaded.
And no the van will not fit inside a garage with a 7 ft door. Not even close, and changing to lower profile tires would not change that on mine.
I can't tell you what to do only what I would do. I will be looking for a lower profile tire when mine wear out. I don't need the 3000 lbs rating on my van tires. The most I've hauled inside the van was about 2000 lb, plus the weight of the van, I was still way under the 12,000 lb capacity of the tires combined!
GoldCo
01-29-2017 06:12 PM
crunky944
05-20-2012 07:59 AM
Mike Bartlett
44
01-19-2011 08:53 PM
LazyJ_Arabians
07-11-2002 08:13 AM
