which size tire will better for super e250? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 04-10-2011, 09:17 PM
Super Econoline Super Econoline is offline
Super Econoline is starting off with a positive reputation.
my 87 e250 wheel is after market 16x7 but tire is LT235-85-16
pretty high body lift but door label say suppose be 215-85-16
but it wont fit in my garage 7 foot if i change tire to 225-75-16 will it look nice
and little low body? or use 215-85-16??
Old 04-11-2011, 04:08 PM
jimbbski jimbbski is offline
jimbbski is starting off with a positive reputation.
I have the same tire on my van (215/85X16). I think the 225/70X16 will lower it some but you would have to check the diameter of each tire to confirm how much.
A couple of things to note would be that your overall gear ratio will change which will reduce your fuel mileage a bit but the shorter tire will lower the vans wind resistance so thats a plus! This could be a wash as far as over all mileage.
Old 04-11-2011, 08:40 PM
i curious anyone have 1975 to 1991 e250 or e350 van will fit in 7 foot garage
or go ramp parking or drive thur fast food limit 7 foot?
Old 04-11-2011, 09:31 PM
does your 215 85 16 come with LT or without? is your wheel 16x6 or 16x7?
does it pass under 7 foot?
Old 04-12-2011, 09:49 AM
Tires were installed by previous owner. The tires are a heavy duty tire at their load capacity is a bit over 3000 lbs when inflated to 80 psi. I usually keep them at 50 front and 60-65 psi rear when loaded.
And no the van will not fit inside a garage with a 7 ft door. Not even close, and changing to lower profile tires would not change that on mine.
I can't tell you what to do only what I would do. I will be looking for a lower profile tire when mine wear out. I don't need the 3000 lbs rating on my van tires. The most I've hauled inside the van was about 2000 lb, plus the weight of the van, I was still way under the 12,000 lb capacity of the tires combined!
Old 04-12-2011, 10:56 AM
Killer RC's Avatar
Killer RC Killer RC is offline
Killer RC is starting off with a positive reputation.
Yeah, you'd have to steal tires off of a ford Escort if you want it to fit in a 7' garage.
16" wheels on 3/4 ton: what size tires? GoldCo 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 01-29-2017 06:12 PM
93 f250 xlt 2wd Tires? BeagleFord 1987 - 1996 F150 & Larger F-Series Trucks 3 01-01-2015 06:53 PM
Dually tire sizes? crunky944 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 05-20-2012 07:59 AM
best cheap tires? jadmt Brakes, Steering, Suspension, Tires, & Wheels 17 10-16-2008 06:04 PM
245/75/16 tires on dually? LazyJ_Arabians Brakes, Steering, Suspension, Tires, & Wheels 3 07-11-2002 08:13 AM
Tags
1987, 1994, 2000, duty, e250, fit, ford, garage, lower, size, stock, super, suze, tire, van, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
