downpipe
#46
Should bolt up to your stock exhaust... Just going to take up some time to line up and get it to come together.
#47
I used a 4 ton porta power when I did the down pipe in the white truck, what I found was it would start to bend the firewall in, but if I kept cranking on it the porta power was just smashing the rubber body mounts and lifting the cab. I ended up using some 2x4's as spacers and standing on the handle of the porta power and REALLY cranking on it. I'd hesitate to say I got enough room for a 3.5" down pipe but I did get the firewall to move some.
#48
I broke the porta power, bent the 2" heavy walled 6' pipe, bent the 6' landscaping digging bar... I can get the 3 1/2" pipe in now, but I know it's going to rub so I raised the white flag and have a 3" DP on the way. I was getting nervous that I was going to break something important!
#49
#50
I realize that I'm resurrecting an old thread here, but is there room to get a BFH in there to smash the firewall back if the transmission is out? Also, I'm looking at downpipes. Is there any perceivable advantage to getting stainless as opposed to aluminized? Also, which downpipe kits do you guys recommend? So far in this thread, it looks like the two piece ones are recommended.
I'm looking at this one: Riffraff Diesel: Diamond Eye 3" Aluminized Downpipe
I'm not going to bolt the new downpipe up to the stock exhaust at all. Will that little flange thing get in the way at all?
#51
Performed the firewall work with the cab off the frame and then installed the diamond eye 3" with cab in position.The dp lined up remarkably well and the fact that it is a two piece provides more ease in positioning it and lining it up as both halves can be twisted from side to side for clearance concerns unique to your truck.Def do the EBPV delete also since there isn't much room to work with.Time for install for the dp about 20 minutes,everything lines up perfectly.
#52
#54
#55
#56
