1999 FORD F250 7.3 DIESEL.... WONT START - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-10-2011, 09:05 PM
coastal stone coastal stone is offline
coastal stone is starting off with a positive reputation.
HELP! MY 1999 FORD F250 7.3 WONT START. IT CRANKS BUT WONT START. I HAVE CHECKED ALL FUSES, REPLACED THE GLOW PLUG CYLINOID, CHECKED ALL RELAYS EVEN BEHIND RADIO, PUT A NEW FUEL PUMP ON, CHECKED THE PCM, BUT I AM STILL NOT GETTING POWER TO THE FUEL PUMP! ANY IDEAS?
Old 04-10-2011, 09:57 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
You have no voltage at the duel pump? Have you checked the fuel pump inertia switch on the passenger kick panel? It is designed to shut the fuel pump off in a crash. There should be a hole that you can stick your finger through below the glove box to reset the switch.
Old 04-10-2011, 10:05 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Is your wait to start light coming on and going off like normal? Are there any other dash lights not functioning normal? Got a chip in the truck?
Old 04-10-2011, 10:23 PM
the wts light does not come on, we have no chip on the truck, although this is where the problem arised. my son took his truck to a friend to install a chip, the chip did not work and now all the sudden neither will the truck.. I am afraid that the computer is fried.. We have done the reset on the passenger side sidekick panel also!
Old 04-11-2011, 12:24 AM
Bonanza35 Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Unplug the fuel bowl heater, and replace the fuse,relay. I think its #30. You can't always tell by just looking. I was going to say chip to because I had the plug in kind once and it just stopped working. Unpluged it and drove off. Keep us posted.
Chet
Old 04-11-2011, 01:55 AM
phil Uberuaga phil Uberuaga is offline
phil Uberuaga is starting off with a positive reputation.
Hey, I just found a similar problem with my 1999 F250 7.3. The wait to start light was acting intermitant and the RPM pointer moves when I'm in the wait to start mode. I'll watch for developments in the above situation to gets some ideas. A funny thing, I was planning to start a trip Tomorrow; wouldn't you know it!
Old 04-11-2011, 03:35 AM
Won,t start
l999 F250 7.3 diesel. Won't start. It turns over fine. The wait to start light is intermittant and the rpm pointer moves during the cranking. Any suggestions would be greatly appreciated. Phil
Old 04-11-2011, 09:00 PM
F350-6's Avatar
Quote:
Well this will be the fun part (not really). Time to ask your son exactly what they did. If they attempted to install, remove, move, wiggle, or even stare to hard at a chip in contact with the pcm WHILE the key was in the ignition, then there is a very good chance the PCM is dead. Even with the truck turned off, having the key in the hole powers up part of the keep alive memory. Plugging a chip into a PCM that is awake can kill it.
Hopefully your son is not one of those "not my fault" types and you can find out for sure if this happened or if we need to keep diagnosing in a different direction. Just in case you get lucky, check all the fuses with a meter and swap the relays around to rule out the simple stuff. A WTS light that does not come on means the PCM is not powering up because they just happen to share the same circuit and fuse.
Old 04-12-2011, 12:01 AM
Foregot about the key in. It has to be out completely or no more PCM.
Old 04-12-2011, 12:41 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Quote:
I still dont understand this? I always think of the key out, just to prevent turning the key while fiddling with the PCM, but I have the chime delete which essentially "makes" the switch always like the key is in the ignition. What else does the PCM use to determine that there is a key in the ignition. All that said though I still pull my keys before working on chip connections or PCM removals, I just dont know what circuit "kills" it with the keys in? If its the key in ignition switch then I need to unbypass that one because I have removed chip and PCM with batteries still hooked up.
Old 04-12-2011, 12:55 AM
Its right in DP Tuners instructions to make sure the key isn't int the igniton while working on the PCM. Its either that or discounnect the batteries. Did you change the fuse for the fuel bowl heater and unplug it?
Old 04-12-2011, 01:00 AM
BigAlsPSD's Avatar
I know its right in the instructions but I have always just wondered. Sorry for the Hijack. Essentially what I am asking is since I have the "key in ignition switch" always sensing that there is a key am I running a large risk of frying a PCM? If so back with the irritating door chimes.
Old 04-12-2011, 08:59 PM
Yes. Any time you play with the PCM "chip" you run a chance of frying the PCM with key in the ingnition.
Chet
Old 04-12-2011, 10:39 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Quote:
In an earlier thread you said you had the key in ignition chime delete and what I higlighted above has me confused becuase that is the exact opposite.
The key in ignition chime delete makes it look like there is NEVER a key in the igniion. If you pull codes you will see a B1532 which is a "key in igtnition failure".
Edit: Even with the chime delete you should always have key out whenever working on the truck.
Old 04-12-2011, 10:42 PM
BigAlsPSD's Avatar
See something so simple that I overlooked, one of those DUH moments, it makes it look like there isn't a key not that there is a key. Silly oversight, lol. Thanks Robin for setting me straight. Although, I have never seen the code, although too I've never pulled the Body codes either just Powertrain and transmission.
1999 F-250 diesel (7.3) cranks but wont start Hawaiianbobby 1999 - 2003 7.3L Power Stroke Diesel 6 09-21-2015 09:58 PM
No start 7.3 Moe power stroker 1999 - 2003 7.3L Power Stroke Diesel 57 01-21-2014 06:08 AM
1999 7.3L lot of crank but no start pkm 1999 - 2003 7.3L Power Stroke Diesel 34 12-09-2011 03:45 AM
1999 f350 Dually 7.3 shutdown, wont start Pineys-Pit 1999 - 2003 7.3L Power Stroke Diesel 59 10-17-2011 04:29 PM
No Oil In HPOP RES ? Crank NO start hot/cold Seven34Life 1999 - 2003 7.3L Power Stroke Diesel 49 01-16-2010 02:51 PM
Tags
1997, 1999, 2000, 250, 73, cranks, diesel, f250, ford, liter, power, start, stroke, turbo, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
