94' Ranger water pump replacement - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-19-2003, 08:57 AM
tfingle tfingle is offline
tfingle is starting off with a positive reputation.
Angry 94' Ranger water pump replacement
I cannot figure out how to rotate/adjust the piece behind the belt adjuster
to remove a final bolt to replace the water pump?
Should I be removing the front cover assembly to replace the water pump?
Old 03-19-2003, 10:23 AM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
2.3L, 3.0L or 4.0L????
Old 03-19-2003, 12:23 PM
Thumbs up 94' Ranger water pump replacement
I appreciate the response
Old 03-19-2003, 02:21 PM
brichardson brichardson is offline
brichardson is starting off with a positive reputation.
Tfingle,
I did my water pump last year. 1993 - 3.0. All I had to do was remove the serpentine belt, the fan clutch and the pulley on the water pump to expose all the bolts. I think there were 5 or 6 bolts. I'm not sure what front cover assembly you are removing. Is the belt tensioner in the way? I not sure if something changed from the 93 model to the 94. It was a pretty straight forward repair. Hope this helps.
Brian
Old 03-19-2003, 02:35 PM
thanks brichardson. there is a casing or bracket that seems to be attached to either the engine block, of holding the rest of the pulleys? This is blocking the removal of the last bolt. I guess I will have to dig deeper. thanks again.
Old 03-19-2003, 11:36 PM
pugsley11 pugsley11 is offline
pugsley11 is starting off with a positive reputation.
i just had my water pump replaced in my 94 3.0 two years ago, i had some one do it for me, but a haynes manual is a help if your still looking to do it yourself. here is some insite out of my haynes.
Remove alternator and mounting bracket from water pump
remove a/c compressor mounting bracket with compressor and power steering pump still attached
then that should open up the bolts for you, i hope it works.
Old 03-24-2003, 09:13 PM
PSKSAM2's Avatar
PSKSAM2 PSKSAM2 is offline
PSKSAM2 is gaining momentum as a positive member of FTE.PSKSAM2 is gaining momentum as a positive member of FTE.
I just bought a high mileage 3.0L and was investigating the water pump/timing chain cover gasket/timing chain procedure. Questions:
1) On a '98 5speed, 4x4, 3.0L, is it necessary to remove the oil pan to change the timing chain (as per the Haynes Manual; they don't show it well in pictures)?
2) Is it really necessary to pull the engine to remove the oil pan on the 4x4 model (again, as per Haynes)?
3) Is the timing chain a concern after a certain amount of miles on this engine?
Thanks,
Jim
Old 03-25-2003, 12:12 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi PSKSAM2 and welcome to FTE
Are you thinking of doing the timing chain just because? Or is there a problem?
According to the Ford <a href="http://motorhaven.autoanything.com/">shop manual</a> you can do the oil pan without removing the engine but you have to remove the front diff assembly and then lift the engine up a ways.
The manual says to remove the oil pan to remove the timing cover but I'm not sure that you really have to. The oil pan gasket might stay in place ok and with a little dob of silicone in each corner you might be ok.
I dont remember ever seeing a timing chain worn out on a 3L. I'm not positive but I think it is probably a double roller chain and even when they are falling off loose they still dont jump.
Old 03-25-2003, 06:53 AM
PSKSAM2's Avatar
Thanks for the reply and the welcome!
I had an '89 3.0L V6 in a Mercury Sable in high school and I remember doing the water pump and having someone ask me why I didn't replace the timing chain at the same time. I was making a list of the things I want/might need to do to the truck once it is fully in my hands and I put that down. But if you say that the timing chain is beefy and not worth the hassle, all the better!
Remove water pump & timing cover on 302 Dashknob 1961 - 1966 F-100 & Larger F-Series Trucks 4 05-20-2015 07:25 AM
1992 E-350 460 water pump replacement question Spaznaut 1968-2013 Full Size Vans 3 05-08-2015 06:44 AM
Water pump for 226 flathead Marauder2004 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-30-2014 07:17 PM
(82) 4.9 water pump removal chermansr 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-01-2013 03:22 PM
water pump to intake manifold hose arsleuthster FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 09-09-2004 03:40 AM
Tags
23l, 30, 40, 94, ac, bracket, change, compressor, ford, mounting, pump, ranger, remove, v6, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
