changing coolant
changing coolant
I'am planning to change the coolant in my 1999 motorhome Ford v10 when the weather warms up. I think I read somewhere that there is drain plugs on the block. If so I will drain it and the radiator and fill it with water and some kind of a flush,run and drain again before filling it with anti-freeze. Will it fill right up or should I be concern about air pockets? Maybe disconnecting the heater hoses would help bleed the air out.Any comment would be appreciated.
I used to park my truck at an angle (nose up) with the radiator cap off. After refilling it, I would start it and let it idle 'till it warmed up, the coolant level would typically drop after the thermostat opened and it would "burp" the air out at the same time. Fill up the rest of the way and cap it.
Boo_Daddy
10-29-2013 07:53 PM
tom302
09-10-2010 08:49 AM
hubler13f
03-27-2010 07:15 PM
