Exhaust System
Doubt anyone makes a bolt in deal. Probably run you $500 or less at a local exhaust shop. I'd recommend since you'll be doing the exhaust to snag a dual outlet exhaust manifold off a newer fuel injected big six before doing the exhaust. It should give a slight performance improvement.
Switch to EFI split manifolds, the increase in power is quite noticeable.
You can then use a Walker 45166 y-pipe. They also make a direct fit cat, muffler, and tailpipe, I'm not sure about the part numbers for those.
A lot of people also choose to go with a turbo-style muffler after the y-pipe, and dump just in front of the rear tire. Usually sounds pretty good.
Here's some good pics:
1981 Ford Bronco Exhaust Upgrade pictures, videos, and sounds | SuperMotors.net
Dynomax PN 17447 (2.25 pipe diameter)
Dynomax PN 17312 (2.5 pipe diameter)
__________________
Follow us on Facebook!
https://www.facebook.com/dynomaxexhaust
http://www.dynomax.com
One of the very first posts I made on this board was how much knowledge there was here, and you provided a little more for me!
__________________
PS your post was another "learning post" for me as well.
Thanks for sharing.
__________________
The walker Y pipe is large internally but often the hole in the one pipe where they are welded together is a restriction.
You can take a 1 7/8" hole saw with an extension and open it up.
(these pic's are from Josiah's 300 build thread)
Stock EFI split manifold, individual pipes:
EFI manifolds, Walker Y pipe:
This is a view inside the Y-pipe with the hole cut out where the rear pipe is fishmouthed and welded onto the front one:
