Help with Radio Install
Hey, guys. My 99 F250 V10 2wd Extended cab with factory CD and Tape deck is up for a new toy. I am replacing oem with ebay DVD 2din deck with GPS and looking where are the wires for Reverse and Parking are located.
Also if anyone knows if it is possible to connect/send false reading to parking brake wire to be able to watch DVD's while driving.
Another thing is anyone have attempted same and how have you mounted player in. I have gotten Metra kit, but it is too small for this ebay radio.
Thanks
Paul
My newly purchased DVD/MP3?GPS Player
Thanks
Paul
Ive done several radio installs, including both my trucks, 1st problem, that head unit is a double din, any superduty from 04-99 has a din and a half radio space. so that head unit wont fit into the space unless you rig it up. I've fit a double din into a din and half of an 03 f-150 before but its alot of work. Your best going with a single din flip out head unit. also you might want to ungrade from that cheaper knock off, ive seen them break and malfunction often, pioneer makes awesome head units for great prices, check my photos and you can see my install.
to bypass the parking break so you can watch movies while driving you need a switch, you hook the parking break wire from the head unit to the switch and then from the switch you run a wire to a good ground. When you want to watch a movie all you do is flip the switch. I have my switch tied right under my dash in front of the pedals, so all i have to do is reach under real quick and flip it.
And to the OP, can't really help you, but a coworker put the switch on his truck. Listens to movies all the time. Not a bad gig.
Thanks, guys.
No worries about tickets. I mainly want to have it for my son, when we go on trips. I have an extended cab and no head rests, so can't have dvd screens there, other wise for $200 i can get set of two.
I have had to cut edges, actualy about 1/4'' on the bottom and 1/2'' on the top of bezel, which makes my screen sit bit higher than bezel, but its perfect when screen opens, no rubbing on the bottom.
I have purchased Metra kit 95-5818, but the only thing I have used was side brackets to lock Player in, two big peaces of plastic that you can mount behind ac controls were too small for Chinese HU.
One last thing have to finish is to figure out why my camera doesn't work. May be that I have connected it right out of stearing column. Should I look for wire pass fuse box?
Thanks again.
I'll post some pictures later.
Thanks again.
Well this is weird thing just happen to me. I made run down to the store (night time) and My screen on HU won't stop flickering. As soon as I shut off my HID's screen came back to normal.
I have gotten some of those Lifetime warranty that I read on on this site and they work perfectly, but now this.
Anybody has any ideas
Give this a shot: Connect the dimmer/lighting wire from the headunit to headlight switch. The dimmer/lighting wire from the factory radio harness is variable voltage can cause issue to the headunit's auto dimmer. The headunit is looking for either +12v or 0v for the dimmer function.
kornfanjoe
05-17-2017 01:30 AM
boston1918
05-17-2017 01:27 AM
pmcgeever
26
02-25-2016 06:51 PM
Smukm
06-07-2012 11:48 PM
