FE engine with 392 chrysler hemi heads??? :) - Ford Truck Enthusiasts Forums
Old 04-09-2011, 10:07 PM
jchamp429's Avatar
jchamp429 jchamp429 is offline
jchamp429 is starting off with a positive reputation.
So been doing some research and came across some references to Micky Thompson building some FE engines in the 60's with hemi heads based on the Chrysler 392 hemi design. One of the articles mentioned that the 392 hemi and the FE have almost identical bore spacing and head bolt pattern. The only thing that doesn't line up too well is the water jackets from what I read. Obviously valve train geometry would need some major modification to work, but has anyone heard of someone taking the 392 hemi heads and making them work with the FE block?
Old 04-09-2011, 10:13 PM
DeepRoots DeepRoots is offline
DeepRoots is gaining momentum as a positive member of FTE.DeepRoots is gaining momentum as a positive member of FTE.
Mickey Thompson's 427 Ford/Hemi Engine - Hot Rod Magazine
seems like it is based on it. Custom poured.
Fascinating.
Drew
Old 04-09-2011, 10:26 PM
jchamp429's Avatar
Ya, very thought provoking It gets those little gears in my head turning and gets me thinking what if I wonder what kind of improvements could be seen over the edelbrocks and blue thunders.
Old 04-10-2011, 11:03 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
"Based on" as in they cut up a 392 head and used the pieces for a mold
Old 04-10-2011, 03:11 PM
jchamp429's Avatar
This is looking even more and more appealing since you can get a pair of those hemi heads all rebuilt for just under $1000. Although I do see the reference to the coolant flow modifications needed seeing as the bottom of the heads look like swiss cheese. Theoretically couldn't you drill and tap the block and head to run external lines to reroute coolant and oil to where it needs to go? As long as you don't weaken the casting of coarse
Old 04-11-2011, 09:59 AM
RapidRuss's Avatar
RapidRuss RapidRuss is offline
FE "Freakin Expensive"
RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.
The only thing those heads had in common with the Chrysler Hemi heads were a slight reference to the intake rocker arms/or exhaust ? dont remember..and the valve covers..the rest was a custom design by Mickey, and the bolt hole and water passages, and oilers were all in a different location...
Plus I have never seen a rebuilt set of 392 hemi heads for $1000 ? hell i know where I can get a 392 shortblock that needs a rebuild for $1500...anbd hell if I could get the heads ready to run for $1K..I'd be on that like stink on a s**t... and stuff it into Our Mustang !
Not flaming anyone..as I knew Mickey on a personal level , and had even been to his house back in the late 70's when I was a Machinist for Garrett Air Research, and he needed a couple of our turbo's like yesterday..I ran them up to his house on my lunch break... Mickey was a real good fab man as well as Danny is..But they never cut up and welded Chysler hemi heads to fit an FE... He got the Idea from just looking how they were made an incorporated what he could for one of his early motors..
Old 04-11-2011, 06:34 PM
jchamp429's Avatar
Here's the link to the set of rebuilt heads for $985.
PAW Engine Parts - Early Chrysler Hemi 392 Cylinder Heads Pair
I just thought it would be a cool conversion, something out of the ordinary, kinda the same idea as putting the mach 1 mustang 4.6 head on the bmw m10 four banger block. Lots of modifying needed but cool idea, I like the idea of people looking at a motor and scratching there heads going 'what is that and how in the h**l did you do it's
Old 04-12-2011, 09:09 AM
RapidRuss's Avatar
Well altho that is a good price on a set of stock rebuilt 392 heads..there would be alot of work to go into them to make them a performance head..and i have to admit I havent ever seen a pair go that cheap before..I think we got $1500 for a set that my uncle had, and they needed to be rebuilt..but they were never milled or hacked on either..and the guy was happy to pay what I asked for them.. But yeah I have always been a firm believer in standing out from the crowd, as long as it wasnt budget busting !
Gearhead yard sale at my place... krooser 1987 - 1996 F150 & Larger F-Series Trucks 13 09-18-2014 08:48 PM
390 vs IH 392 and Dodge 383 iggybob44 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 23 09-18-2012 07:37 PM
Bronco Hemi Swap 64shrtbed Engine Swaps 16 05-02-2008 05:52 AM
ford hemi head? theguy_88 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 02-18-2006 09:44 PM
Legendary Hemi androidscrew General Automotive Discussion 15 03-20-2004 07:59 AM
Tags
392, 46, conversion, cut, early, engine, fe, ford, head, heads, hemi, parts, truck, v8, welded
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
