7.3 Oil Leak top of engine - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-09-2011, 01:52 PM
ciccarp ciccarp is offline
ciccarp is starting off with a positive reputation.
I have a oil leak from a round cover at the back of the high pressure oil pump. The round cover has a snap ring. What is the cover for, what is behind it?
Old 04-09-2011, 02:15 PM
DieselOrings's Avatar
DieselOrings DieselOrings is online now
SPONSOR
DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.
It is rare that the leak is actually on the rear plate. Any leak on the HPOP, discharge hose fittings, plug on the back, engine gasket or "non-serviceable" plug will flow to the rear of the pump and collect on the lip for the c-ring.
You will need to clean the HPOP and engine valley with simple green and rinse with garden hose pressure. Stuff paper towel under and around the pump and take it out for a short run. Pull the paper towels out slowly until you can determine where the actual leak is originating. With that, we can determine how to repair the pump.
__________________
Bob aka 'guzzle'
Specializing in Viton o-rings and leak repair kits for the 7.3L diesels
(970) 368-4455
guzzle's Mods & Maintenance website
Old 04-09-2011, 02:27 PM
The oil is leaking at the round cover. The higher the RPM the more it leaks, up to a stream. What I do not know is, can the cover be replaced? Is there an o-ring that is leaking? I do not know what is behind the round cover?
Old 04-09-2011, 02:32 PM
SPONSOR
There is a single o-ring that seals the cover to the pump. Nothing will fall out when the back plate is removed but the only way that I have been able to replace this o-ring without damaging the new o-ring is by removing the pump from the engine bay.
__________________
Bob aka 'guzzle'
(970) 368-4455
Old 04-09-2011, 02:34 PM
Thanks! Do you know if the o-ring is a seal for that cover? I cannot find any other leak?
Old 04-09-2011, 02:44 PM
binuya's Avatar
binuya binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
ciccarp,
To be sure, did you look in that area with inspection mirrors, rags, and good lighting while running it? When I had a leak in the same area, I was convinced it was coming from that same round 'plate/plug' you are referring to, when in fact it was traveling to that area from a brass plug nearby.
It took me a while to track down the leak, but when I did, it was easy to see how it could appear to come from where I thought it did by the way it traveled.
Old 04-09-2011, 02:54 PM
Alvin, What was the brass plug to/for? Did you have to pull the pump, was it just loose?
Old 04-09-2011, 02:58 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
Here is a cutaway of the pump for you. This should help you see what is going on.
Old 04-09-2011, 03:01 PM
twtcad's Avatar
twtcad twtcad is offline
twtcad is gaining momentum as a positive member of FTE.
Quote:
<br />
<br />
I believe that is the non-servicable plug, which is replaceable but yes you have to pull the pump to fix either leak.
Old 04-09-2011, 03:20 PM
Thanks everyone! Yes, it is the brass plug that's leaking! Off to get the o-ring!
Old 04-09-2011, 03:23 PM
johnbrown johnbrown is offline
johnbrown is starting off with a positive reputation.
oil leak
Hi, Woodnthings, do you have cut away of a 95psd HPOP, as i had fix the
non serviceable plug on my truck.
I called ford parts today and they told me they want $921.00 for the HPOP +TAX,then if you can not do the job yourself add about 4 to 5 hrs labor and if all that is wrong with your pump that is the plug which will cost you about $75.00 plus your time quite a savings i think,thanks.
Also is there a spring and check ball under plug can not find out for sure
but i stuck a q-tip down into hole and could not touch bottom,but i am going to put pump back on hope for the best.
binuya's Avatar
In Ken's picture, right next to the 'plate', is the plug which leaked on me. It requires an o-ring and Loctite to seal that plug. Bob/Guzzles has that one, and the Loctite is required for it to seal properly.
Old 04-09-2011, 03:29 PM
binuya's Avatar
I just noticed your last post. Make sure you use the proper Loctite on that plug or it will not seal right. Ask me how I know. I finally went to a Ford parts counter and paid too much for the right o-ring and Loctite package to get it right. (Needed the truck that day)
Clean and degrease the heck out of the threads before installing. I used Q-tips. Good luck.
Old 04-09-2011, 03:33 PM
I do not have any pictures specific to the older HPOP's.
Old 04-09-2011, 05:05 PM
oil leak
Hi, Woodnthings, do you know if there is even a spring and check under
plug i do not think there is,also when it comes to tightening the bolt to
gear how do you keep it from so you can put enough torgue on bolt as
it calls for 95ft lb of tourge,thanks
valve cover gaskets jeffri116 1997 - 2003 F150 0 05-09-2016 11:14 AM
vct seal on valve cover leaking oil? riverratba 2004 - 2008 F150 5 11-24-2012 07:36 PM
front oil seal orientaton, aftermarket timing cover RockWVU Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 10-10-2012 09:34 PM
Passenger side oil pan leaking? duggyb 1994.5 - 1997 7.3L Power Stroke Diesel 24 03-22-2012 11:32 AM
leaking on driveway Skip1970 1999 - 2003 7.3L Power Stroke Diesel 83 11-01-2010 06:46 PM
Tags
0il, 2001, 73, 99, diesel, engine, excursion, f250, f350, ford, leak, leaking, oil, repairs, top, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
