7.3 Oil Leak top of engine - Page 2 - Ford Truck Enthusiasts Forums
Old 04-09-2011, 04:16 PM
binuya's Avatar
binuya binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Quote:
Originally Posted by binuya View Post
I just noticed your last post. Make sure you use the proper Loctite on that plug or it will not seal right. Ask me how I know. I finally went to a Ford parts counter and paid too much for the right o-ring and Loctite package to get it right. (Needed the truck that day)
Clean and degrease the heck out of the threads before installing. I used Q-tips. Good luck.
Just checked and it is Loctite 680 that came with my orings.
Old 04-09-2011, 04:31 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
As old-timers in this forum would expect me to say about now:
Make sure those threads are SPOTLESSLY-free of oil before using LocTite. Brake cleaner, Q-tips, re-do, re-do, re-do!
LocTite on only the first three threads of the male threads, insert finger tight, torque if you have a wrench, but don't over-tighten. Remember, it's an aluminum pump body!
After the LocTite sets up, DO NOT ever "check" that plug again. Re-torquing will break the LocTite, causing eventual O-ring failure.
Don't ever "check" or "tighten" any of them, for the same reason.
Those are AS568A-906 O-rings, available from Guzzle's.
Don't forget to refill the HPOP with oil through the fill hole on the top of the reservoir before attempting an engine re-start.
Pop
Old 04-09-2011, 06:52 PM
johnbrown johnbrown is offline
johnbrown is starting off with a positive reputation.
Hi, Rubberduck, i just finished fixing HPOP plug on bottom of pump,truck is together and tried to start it but will not fire up,is there something that i forgot to do that
prevents truck to start,cracked my cross over to bleed air from system and oil came out,but still not starting,pushed air fitting in and bled air out of fuel system still not
starting,WHY ME,it is probaly something silly and stupid,thanks
Old 04-09-2011, 07:15 PM
Did you pre-fill the HPOP with oil through the filler plug on the top of the reservoir?
Pop
valve cover gaskets jeffri116 1997 - 2003 F150 0 05-09-2016 10:14 AM
vct seal on valve cover leaking oil? riverratba 2004 - 2008 F150 5 11-24-2012 06:36 PM
front oil seal orientaton, aftermarket timing cover RockWVU Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 10-10-2012 08:34 PM
Passenger side oil pan leaking? duggyb 1994.5 - 1997 7.3L Power Stroke Diesel 24 03-22-2012 10:32 AM
leaking on driveway Skip1970 1999 - 2003 7.3L Power Stroke Diesel 83 11-01-2010 05:46 PM
Tags
0il, 2001, 73, 99, diesel, engine, excursion, f250, f350, ford, leak, leaking, oil, repairs, top, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
