ZF S542 Input Shaft Seal - Ford Truck Enthusiasts Forums
Old 04-09-2011, 06:33 AM
oscar4pbr oscar4pbr is offline
oscar4pbr is starting off with a positive reputation.
According to the service manual downloaded from ZF.com and the Ford 1996 service manual I have the input shaft oil seal can be changed without having to disassemble the transmission. Has anyone ever done this? I have just completed a ZF swap, could not be happier with all aspects of the trans swap except leaking front seal.
"Note: For 4.9L and 5.8L engine applications the through-bore of oil seal is designed such that oil seal can be removed without having to dissemble the transmission if removal and replacement of oil seal is all that is required. "
Old 04-09-2011, 12:10 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
It is quite simple like the book says. Just pop out the old seal, and put in the new one
Old 04-09-2011, 03:34 PM
I was hoping it was quite simple like the book says but how many times has quite simple turned into a major task. Just wanted someone who had done it themselves to tell me it was as simple as it appears. Thanks.......
Old 04-30-2011, 04:34 PM
Not so simple
Ok got trans out and old seal out. However(BIG HOWEVER) new seal from Ford or Autozone is 50mm x 35 mm. The hole size around the shaft is 42mm, so I'm assuming a special(non-stock seal will have to be found. You can't push a 50mm seal in though a 42mm hole. I've thought about die grinding lip out of the way so stock seal will slide into place. Input folks please.
Old 05-01-2011, 08:09 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
I can't remember for sure but I want to say I replaced the input seal from the inner side of the case. Can you tell if there is a lip on the bell housing side of the seal bore? If there is not a lip, maybe you have an input seal for another engine configuration? Is the ID of the seal the same as the old one?
Old 05-01-2011, 08:28 AM
Yes there is a lip on bellhousing side, that's the 42mm size. Yes the inside diameter is the same as the old, 35mm. I'm looking at a different seal with dimensions of 42x35x8, using the lip to hold seal in place. I'm assuming that's what the Ford service manual and ZF manual are referring to when it says to drive new seal in flush but not into the transmission. Thank you for the reply.
Old 05-02-2011, 05:48 AM
EPNCSU2006's Avatar
How were you able to get the old seal past the lip?
Old 05-07-2011, 07:30 PM
I worked the old seal until it broke and then grabbed the end with needle nose pliers. Pulled it out basically straighting as it came out. Since my last post I gave up, opened case and installed new seal. Trans has been re-assembled but not back in truck yet. Wish I had opened it to start with but manuals said I could do it from the bellhousing side. Thanks for the replies and I appreciate any input.
Old 05-08-2011, 08:51 AM
EPNCSU2006's Avatar
What did you use to seal the case? Loctite makes an anaerobic flange sealant (I think it's 518) that is supposed to be better to use than RTV silicone. The RTV will corrode the aluminum according to the Ford service manual.
Old 05-08-2011, 11:24 AM
Brought the gasket maker from Ford per their part number. Boy, they're proud of it too.
Old 05-08-2011, 02:12 PM
EPNCSU2006's Avatar
I bet so. I went looking for it at the local dealer and he said it was superseded or something so I ended up getting the loctite 518 for about $20 from Fastenal instead.
Special tools_ Rear Drive Axle/Differential Ford 10.50-Manual Transaxle/Transmission ZF 6-Speed Specialtools Vendor Specials, Discounts, Product Announcements & Group Buys 3 07-06-2016 10:44 AM
ZF input shaft play: new bearing or full rebuild? Ford F834 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 08-31-2015 12:50 AM
Any C6 transmission experts? markeyd 1967 - 1972 F-100 & Larger F-Series Trucks 13 06-18-2015 01:56 PM
What should I do about a 92 4.0 leaking oil so bad? 1998Ranger25L153CID Ranger & B-Series 3 01-06-2015 02:51 AM
Is there a seal on the tailshaft housing of the C6 on a 4x4? CountryBumkin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 08-22-2014 01:42 PM
Tags
2000, 42, c6, ford, fron, input, reseal, s5, s542, seal, shaft, swap, taurus, transmission, zf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
