Question about tires. And diy bed liners. - Page 2 - Ford Truck Enthusiasts Forums
Old 04-09-2011, 02:15 AM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
Quote:
Originally Posted by cole.jace View Post
And the DIY bed liner was just out of curiosity I don't think there is a bed liner installer around here.
Where abouts are you?
Old 04-09-2011, 04:04 PM
cole.jace's Avatar
cole.jace cole.jace is offline
cole.jace is starting off with a positive reputation.
Estevan saskatchewan Canada
Old 04-09-2011, 05:53 PM
skyfox10's Avatar
hmm... I'll have to see if we have anyone close over there, just for the sake of knowing.
Old 04-09-2011, 06:21 PM
91chevywt's Avatar
91chevywt 91chevywt is offline
91chevywt is gaining momentum as a positive member of FTE.
My '88 had one of the DIY roll-on liners, not sure if it's herculiner, duplicolor, or w/e, but it's coming off big time. Quality wise it's similar to flat black rustoleum with a couple of handfulls of sand in it. I'd stay away from the cheap, one part systems, unless you plan on never using the bed. Even then, it'll probably come off eventually.I threw a bed mat over my crappy liner until I decide to do anything. I'll probably just flat-black over the chipped parts and call it a day...touch it up when it gets scratched again.
Old 04-11-2011, 12:53 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I love my BFG AT tires, and thats all I will run on my truck.
As for DIY bedliners, I don't care for them at all. They don't hold up nearly as well and after some time in the sun they become gray and chaulky.
I don't really care for spray in bed liners to begin with. I just have a rubber mat. If I ever have to get one it will probably be Line X.
Old 04-11-2011, 01:02 AM
StumpPullerF1 StumpPullerF1 is offline
StumpPullerF1 is starting off with a positive reputation.
Buy American, get the Goodyear's. A little more money but worth it, i bought the duratracs and they're perfect for me. No road noises, good wear, and they are pretty aggressive if you need that. Also, just what i've heard about the diy bedliners is they fade in the sun and can crack which is tough to fix. Good luck
-Jesse
Old 04-12-2011, 01:13 PM
91chevywt's Avatar
Here's how the cheap bedliners end up
Old 04-12-2011, 01:40 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Use a quality DIY bed liner
http://www.ford-trucks.com/forums/96...iner-done.html
For the tires. I have had BFG all terrains and I dont like em.
I am currently running Falkin WildPeaks on my ranger. I like em. Most of the time when plowing i just leave it in 2wd. I have about 20k on them so far and are wearing well. I will most likely get 100k out of them if not more
Old 04-12-2011, 06:07 PM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
I'd stay away from the DIY bedliners. While I like to do everything myself as much as anybody else here, any DIY kit is going to be limited because it has to have a shelf life whereas commercial products like Rhinoliner and Line-X are a two part mixture that hardens in minutes after being sprayed on.
I've had Hurculiner and I loved it until summer rolled around and the UV broke it up big time. I did a full three coats and by early July it was shrinking around each rubber granule to the point that I could see the scuffed up paint again.
With the new bed and paint job, I'm forking out for a Line-X bedliner. My dad has it on two of his trucks and it's survived 2 years of farm use so far.
From what KevinGnWV is saying, it sounds like Rhinoliner works really well too. In my personal experience, I've only seen one truck with Rhinolining and it was chipping all over the place, but I'm not sure on the trucks use nor the installation quality, so take it with a grain of salt.
As for tires, I've still got the Firestore Transforce AT's that my dad had on the truck before I got it from him. They are great on the road and they wear very slowly on pavement and on gravel (mostly crushed limestone) even with a pallet of seed or other heavy loads in the truck at all times. They have never let us down in the field (I'm in Iowa so lots of black dirt, I don't know how they would handle clay or other soils), and snow traction isn't bad, but they really suck on ice.
Old 04-12-2011, 06:18 PM
Quote:
The Al's DIY bedline I put the link to is a 4 part mixtue just like SCORPION bed liner and similar to the line x and rhino. It is not garbage like herculiner or the duplicolor crap they sell
Old 04-12-2011, 07:56 PM
DIYiT's Avatar
I must have missed your post (forum posting at work will do that); I haven't heard of Al's before; now you've got me wondering if Line-X is the correct route...
Old 04-12-2011, 08:19 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Line-x is very nice. My GF mom has it in her truck. I just wasn't going to spend $400 for a bedliner.
My Hurculiner is holding up great. I do put quite a bit of stuff in my bed also.
I also Hurculined my dads 07 F150 and its doing great too.
91chevywt: Looks like the walmart bedliner.
  #28
Old 04-13-2011, 05:22 AM
Quote:
And where does herculiner come from?
  #29
Old 04-13-2011, 05:24 AM
For a spray in bedline that is completely tintable and DIY your self with shop quality results, it is a win win
  #30
Old 04-13-2011, 11:06 AM
91chevywt's Avatar
I'm really not sure where it's from, but my walmart sells Herculiner. It's all dried out from the sun. It's almost all gone under the bed mat. Just want to add, a previous owner did this, not me
Picked up a 55 C600. ndfastang Large Truck 4 07-12-2014 12:46 AM
Ride height is better now quesey 1994.5 - 1997 7.3L Power Stroke Diesel 15 04-06-2014 02:11 PM
Project "Old School Work Truck" F150 cobra_4 2009 - 2014 F150 39 07-12-2013 12:20 PM
Now here is a farm truck! cole.jace 1987 - 1996 F150 & Larger F-Series Trucks 16 04-28-2011 02:13 PM
Rear wheel well liners Rutcutter 6.7L Power Stroke Diesel 5 12-11-2010 02:54 PM
Tags
atv, bed, bf, cooper, diy, duplicolor, duratrac, goodrich, goodyear, heavy, kit, lineing, liner, loads, trendsetter, truck, walmart, wrangler
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
