Brake Lights: Switch, Wiring: HELP!!! - Ford Truck Enthusiasts Forums
Old 04-08-2011, 09:40 PM
TEXFARLEY TEXFARLEY is offline
TEXFARLEY is starting off with a positive reputation.
1995 f250 with the brake lights on at all times.
Replaced turn switch, no help. Doesn't appear to be turn or hazard flasher.
However, I have 12V on both sides of the Brake Switch. Is this normal? Can't tell from wiring diagram.
Old 04-08-2011, 09:42 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
Do you have a third brake light on that truck? Is it on? That would be wired direct from brake light switch, not through multi-function switch. But... have you checked the actual brake light switch? It sounds to me like its bad. There would only be 12 volts on both sides if its closed creating a circuit....
Old 04-08-2011, 09:47 PM
Have a third light, but it's always off, as are the "courtesy" lights on the top rear of the cab.
12V on both sides at brake switch connector, with switch disconnected.
Old 04-08-2011, 10:30 PM
Volvo92906's Avatar
Id be pulling bulbs and checking voltages. Wire schematics to find out whats going on. Now I am curious.
Old 04-08-2011, 11:18 PM
Yep, one of those Saturdays. I'll let you know what I find
Old 04-09-2011, 10:24 PM
Something in dome circuit is shorting to GND, pulling up GND on rear, cargo assemblies.
no brake lights mike 1973 - 1979 F-100 & Larger F-Series Trucks 16 01-07-2016 10:56 PM
No Brake Lights PJPVI 1968-2013 Full Size Vans 4 01-13-2014 07:44 AM
Brake light wiring issues 78 F-350 quadrazer 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-23-2012 11:54 AM
1986 F150 XLT Brake Light Problem wagontrader 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-14-2011 03:24 PM
1963 F100 Brake light don't work darinbrooks 1961 - 1966 F-100 & Larger F-Series Trucks 4 12-01-2010 07:23 AM
Tags
1966, 1995, 2009, 350, brake, bronco, diagram, f150, ford, jump, lights, multifunction, switch, truck, van, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
