The Inline Six Cylinder (4.9L 300CI) - Page 2 - Ford Truck Enthusiasts Forums
Old 04-09-2011, 08:14 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Interesting reading there Syfox10.
Old 04-09-2011, 09:20 PM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
yeah, that whole site is pretty cool, it has a lot of information on various techniques on saving fuel, and why the do or don't work. There are a lot of useful "tidbits" there.
Old 04-11-2011, 12:31 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
If you want to make your 300 more powerful, here's what you do!
Rip it out and instal a 390.
There you go! Three times the power!
Old 04-12-2011, 07:25 PM
Thrasher49 Thrasher49 is offline
Thrasher49 is starting off with a positive reputation.
I appreciate everyone's advice! I think I am gonna throw a 460 in there. I was playin' with my dad's Bronco with the 302 and you just can't beat the sound of a V8 and the power of a big block. Here's my next question. Like I said, I wana throw Ford's 460 big block in there. What all would I have to do? New engine mounts and a transmission?
Old 08-24-2012, 12:05 PM
jeffbjones62 jeffbjones62 is offline
jeffbjones62 is starting off with a positive reputation.
pc. of ****
I have 92f150 300 6cyl. My problem is very high idle & over htg. It all started after it started running very sluggish one day . I did a tune up Plugs,wires Dist. cap, rotor button,filters,etc. didnt help. Replaced fuel pump,fuel filter checked vac. hoses ok. took intake off cleaned good. now runs great except very high idle & over heats . took t-stat out still over heats. whats wrong. Replaced air bypass valve , switched egr valves with another i had. could a chk valve be clogged causing these problems. the chk. valve down line from egr .
Old 08-24-2012, 10:25 PM
Truckin Bob Truckin Bob is offline
Truckin Bob is gaining momentum as a positive member of FTE.
Quote:
jeffbjones,
It's probably best to start your own thread about your problem(s), more viewers, and of those that are viewing, you'll most likely have a very knowledgeable (expert) person help you out.
That said, I think you're suffering from a pretty massive vacuum leak, which in turn, is causing your truck to run WAY too lean. Lean motors run hot.
Start a new thread and see where it goes.
Bob
Old 08-25-2012, 12:05 PM
OK THANKS Truckin Bob
Old 08-25-2012, 12:18 PM
1992 F-150 2 WD 6Cyl. inline 300
Truck started running very sluggish one day. i did tune up. Plugs,wires,dist. cap,rotor button,all filters,etc. changed egr valve,air idle valve took off intake cleaned real good. finally got it running good but now over heats and very high idle. please help ready to use it for target practice.
Old 08-25-2012, 12:35 PM
Ummmmmm Jeff, you're still in this thread.
Go to the page that has all of the topics listed, then click on "New Thread", give it a title, and then post your question.
Bob
Old 08-25-2012, 12:43 PM
OK Thanks Bob Im new at this if you cant tell
Warning don't buy from Performance Machine In TN coolfeet 6.0L Power Stroke Diesel 54 10-27-2015 09:45 PM
WTB: 48-52 Ford F1 3 Speed Transmission ddiaz12 WTB - Parts & other 0 02-26-2015 01:37 PM
WTB: 48-52 Ford F1 3 Speed Transmission ddiaz12 WTB - Ford Trucks & other vehicles 0 02-26-2015 01:33 PM
Calling all Artists! 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 05-30-2012 09:13 PM
Anone have a f250 or f350 with bad motor? I'll take it cincinnati_kid 1999 - 2003 7.3L Power Stroke Diesel 30 11-04-2009 09:22 AM
Tags
1994, 300, 300ci, ac, air, cylinder, eliminate, f150, ford, forums, hose, intake, oil, pump, replacement, smog, straight, supercharged
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
