96F350 drw need rear axle u bolts - Ford Truck Enthusiasts Forums
Old 04-08-2011, 03:02 PM
MONAVIERONJON MONAVIERONJON is offline
MONAVIERONJON is starting off with a positive reputation.
Have two cracked u bolts on the rear axle,def gonna need some new ones,any insight as to sources other than stealership or craigslist as i prefer new parts?thanks much in helping me get this solved!!!!!!!
Old 04-08-2011, 04:30 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Measure your existing u-bolts then call Bob @ Leaf Spring U-Bolts, www.ATSSPRINGS.com
Old 04-08-2011, 06:45 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Old 04-08-2011, 08:35 PM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
ha!!!
I can PM you dimensions if you're interested. . .I had a set of new 5/8" dia. U-bolts made for my project truck which I kept when I got rid of it. I also have the plates as well. They fit a Dana 70, and a 3"-4" lift block. . .they have lots of thread. Cost me $55 new from spring menders local, I'm sure we can work something out if you need them. . .I'm easy going, $$ wise
Old 04-18-2011, 08:27 PM
sure pm me with dims and contact info,have the center pin on one side sheared off,seems that it threads into the top of the axle lobe plate if thats correct
Tags
1999, 250, 96, 97, axle, bolt, bolts, craigslist, f250, f350, ford, kentucky, mountaineer, rear, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
